edelbrock carb issues
Old Aug 31, 2010 | 05:28 PM
80vert's Avatar
80vert
Default edelbrock carb issues
Hey guys
I have an edelbrock carb on my 80 thats not working
Car wont start but if i run the fuel line into it and start it up it runs fine.
I pulled the top off and noticed the float was stuck...loosened it up,reassembled and it fired right up....today....same thing..wont start.
Should i rebuild or buy new?
I dont even know where to find the model number on it?
Anyone??
Old Sep 1, 2010 | 07:47 AM
929nitro's Avatar
929nitro
If I remember right model number should be stamped on front face of mounting flange. Can check tonight when I get home.
Old Sep 1, 2010 | 08:57 AM
80vert's Avatar
80vert
thanks nitro
really appreciate it
Old Sep 1, 2010 | 09:28 AM
KSM's Avatar
KSM
Sometimes the needle seat breaks down and get a little sticky. Moving it might(like you did) will help for a while be it will go back to not functioning fairly quick.
Just replace the float needle valve and all should be fine.
Old Sep 2, 2010 | 08:08 AM
929nitro's Avatar
929nitro
As I thought the model number is on the right front mounting flange. It will be a number like 1403 1404 etc.
Old Sep 2, 2010 | 08:23 AM
80vert's Avatar
80vert
Thanks everyone....i was able to clean it and found the number
Its a 1406-1595
I guess the next step is to call edelbrock and order parts
Old Sep 2, 2010 | 03:51 PM
929nitro's Avatar
929nitro
Don't klnow where you are located. Some of our Napa Stores and some speed shops have these things in stock. Just a thought.
Old Sep 2, 2010 | 07:25 PM
80vert's Avatar
80vert
in conn here
will check out napa and local shops
thanks for everything
To edelbrock carb issues
