Temp Sensor help needed 1972 350
Old Sep 1, 2010 | 08:35 PM
mobjack68's Avatar
mobjack68
Default Temp Sensor help needed 1972 350
Temp sensor needed in each head...
can someone advise me as to the most correct sensor and placement???
thanks
Old Sep 1, 2010 | 09:06 PM
Gordonm's Avatar
Gordonm
The temp sensor for the gauge is in the drivers side head. The one in the passenger side head is for the emissions. not needed in most cases unless you are going NCRS.
Old Sep 1, 2010 | 10:17 PM
7T1vette's Avatar
7T1vette
As mentioned...sensor in the right cylinder head is for the TCS system (transmission controlled spark). It has 2 temp switches in it: one that opens below a certain temp and another that opens above a 'hot' temp. The TCS won't function if below temp on the low one or above temp on the 'hot' one. You must get sensors that are for your year car to be sure they are correct. Check to see if Willcox sells them.
To Temp Sensor help needed 1972 350
