CE replacement engines?
Old Sep 13, 2010 | 04:32 PM
rgarrett's Avatar
rgarrett
Default CE replacement engines?
I vaguely remember someone posting (either here or another site?) that CE blocks were supposed to have been stamped with the vin on another part of the engine by the dealer doing the replacement(not on the vin pad where the CE is stamped)? The pad on the engine has the CE stamping and nothing else, I imagine even if this was supposed to happen it probably didnt get done much, but just interested if anyone knows...
thanks
Old Sep 13, 2010 | 04:42 PM
7T1vette's Avatar
7T1vette
GM probably recommended a stamping format for the CE [warranty replacement & over-the-counter] engines. But dealerships did what they wanted and many had their own scheme. The only way to tie a CE engine back to a car and specific dealer is via the purchace invoice for that engine.
Old Sep 13, 2010 | 05:06 PM
Mike Ward's Avatar
Mike Ward
I've never personally seen a CE engine with the VIN stamped on it. Could have happened, although not common.,
Old Sep 13, 2010 | 05:11 PM
rgarrett's Avatar
rgarrett
found it, this was on a camaro forum... anyone know if this was true procedure?
"The CE prefix represents a block replaced under the 5/50 warranty. The B is seen occasionally and its relevance is unknown. The final numbers represent the sequential number this block falls within the total number of GM replacements. If the installing GM dealer followed procedure a vin # will be stamped on the rough casting near the oil filter. "
ill check on my block and see if anything is there...
Old Sep 13, 2010 | 07:09 PM
Tom73's Avatar
Tom73
Never heard that one. But then what difference does it make. It is a CE engine and not the original.
Old Sep 13, 2010 | 07:14 PM
baxsom's Avatar
baxsom
If that sort of thing is actually important.
Old Sep 13, 2010 | 07:47 PM
rgarrett's Avatar
rgarrett
well it would be interesting to know the history?
Old Sep 13, 2010 | 07:51 PM
joewill's Avatar
joewill
i doubt if very many dealers even had the stamps. i am sure laws stated that for identification and theft recovery that vin stamps needed to be placed on the engine.
some states even insist that engines have vin# stamped on them.
some overzealous DMVs will even try to impound the car... it's happened before...
Old Sep 13, 2010 | 11:24 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
What years did a Corvette have a 5/50,000 mi warranty ? or any "GM" car for that matter............Curious ???
Old Sep 14, 2010 | 09:24 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by 427SIXPACK
...What years did a Corvette have a 5/50,000 mi warranty ? or any "GM" car for that matter............Curious ???
I'm thinking the 5/50 warranty began about 1966 or so. Prior to that, the new vehicle warranty period had been 24 months. GM instigated the CE blocks to attempt to track the number of warranty engine replacements they were doing for new cars.
JohnZ has an article about CE blocks in Corvette Enthusiast.
Old Sep 14, 2010 | 11:17 AM
427SIXPACK's Avatar
427SIXPACK
1966 to ??? i can only recall 36/36 .........and 12/12 earlier
Old Sep 14, 2010 | 11:19 AM
early shark's Avatar
early shark
Part of your quote is correct, in that the 1969 Camaros produced at the Van Nuys, CA assembly plant did in fact have their VIN numbers stamped in the rough casting near the oil filter location. My May 1969 SS/RS 396 Camaro convertible had the vin # at that location. However, this wasn't a CE cylinder case.
Old Sep 14, 2010 | 06:43 PM
Mike Ward's Avatar
Mike Ward
Yup, started in fall 1966. GM was one of the last to offer it.
Old Sep 14, 2010 | 07:08 PM
427SIXPACK's Avatar
427SIXPACK
when did it end ? and what did it change to afterwards ?
Old Sep 14, 2010 | 07:13 PM
7T1vette's Avatar
7T1vette
My recollection is that the 5 year/50,000 mile warranty only appied to the emissions related systems. The warranty on the drivetrain was 3 years/36,000 miles and the rest of the car was 12 months/12,000 miles. But, I've slept since then...so I may not be correct.
Old Sep 15, 2010 | 12:12 AM
BBCorv70's Avatar
BBCorv70
Sounds about right. You didn't get much of a warranty back then. Cars generally lasted up to 100,000 miles or maybe 7 years?
Old Sep 15, 2010 | 07:43 AM
joewill's Avatar
joewill
back then cars lasted about 75000 miles before leaking and burning oil, getting rusted out panels etc...
To CE replacement engines?
Old Sep 15, 2010 | 09:32 AM
Mike Ward's Avatar
Mike Ward
For you doubting Thomases, here's an article from 1962 talking about Chrysler's 5/50 warranty on the powertrain.
http://books.google.com/books?id=2Ns...rranty&f=false
Here's another article from 1966 announcing GM's copy cat version.
http://books.google.com/books?id=rNM...page&q&f=false
Old Sep 15, 2010 | 10:06 AM
BBCorv70's Avatar
BBCorv70
It appears you are right.... The power train had a 5 year/50,000 mile warantee in 1970. Rest of the car had 12 month, 12,000 miles...
http://www.roadandtrack.com/tests/ca...t-454-corvette
Old Sep 15, 2010 | 10:14 AM
Easy Mike's Avatar
Easy Mike
Don't know when it ended, but it would have changed when it got trendy to offer better new car warranties as a marketing ploy.
Isn't it 10/100K these days?
