help deciphering date codes on heads
Old Sep 13, 2010 | 06:26 PM
crw1969's Avatar
crw1969
Cruising
Default help deciphering date codes on heads
I have a 1969 350/350. Head number codes are 3927186 on both left and right.
I was told that the 'other' coding on the heads is
- R128 (for the right side)
- J78 (for the left side)
I can't figure out how to read these numbers. I believe that they are date codes for date of manufacture.
Any ideas on what these are and what they mean?
Old Sep 13, 2010 | 06:36 PM
joewill's Avatar
joewill
my book shows that the 3927186 head is a 300 HP corvette head and also a 370 HP corvette head, although there were no 370HP corvettes in 1969.
if your valves are 1.94/1.50 then it is a 300HP head, if 2.02/1.60 then 370 HP.. so depends on your valve size what application. I am sure someone will chime in on further clarification..
you may have a 350-300 base engine, are there other clues to confirm a 350-350?
the date J78 means Oct 7th 1968,
there is no 'R' designation, i expect it really says 'K 12 8' for the other head which means nov 12 1968.. look again to clarify.
Old Sep 13, 2010 | 06:43 PM
Alan 71's Avatar
Alan 71
Hi crw
The spec guide I'm looking at does list the 86 as one of the heads used for 350 hp engines in 69.
Regards,
Alan
Old Sep 13, 2010 | 06:49 PM
crw1969's Avatar
crw1969
Cruising
Thanks for the reply.
Here's the information I had for 68 and 69 showing the nums matching mine for a 1969. The thing i can't figure out is how I get a 1968 date stamp with a 1969 head (note that the numbers for my heads don't show up on the 1968 list).
1968 Corvette Casting Numbers
Application Block Cylinder Head
327 - 300 HP (early) Base 3914660 3917291
327 - 300 HP (late) Base 3914678 3917292
327 - 350 HP L79 3914678 3917292
1969 Corvette Casting Numbers
350 - 300 HP (early) Base 3932386 3927186
350 - 350 HP (early) L46 3932386 3927186
350 - 300 HP (mid) Base 3956618 3927186
350 - 350 HP (mid) L46 3956618 3927186
350 - 300 HP (late) Base 3970010 3947041
350 - 350 HP (late) L46 3970010 3927187
Old Sep 13, 2010 | 07:08 PM
Alan 71's Avatar
Alan 71
Hi CRW,
It's easy... the heads being produced in the fall of 1968 were going on the 1969 model year cars that were already in production. The date in this case doesn't refer to the model year but rather when the heads were cast.
My mid-January 1971 car has many, many, 1970 dated parts. The car has an intake manifold with an August 1970 casting date but the 1971 base engine intake casting number.
Regards,
Alan
Old Sep 14, 2010 | 10:32 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Alan 71
It's easy... the heads being produced in the fall of 1968 were going on the 1969 model year cars that were already in production. The date in this case doesn't refer to the model year but rather when the heads were cast...
Bingo.
CRW: you engine was assembled at Flint, Michigan, then shipped to St. Louis and was on hand in the plant before your Corvette was assembled. Any casting date you find on your engine, and the engine assembly date stamped on the pad on the block, should be earlier than the time/build code on your trim tag.
To help deciphering date codes on heads
