Horn Problem
Old Sep 15, 2010 | 11:27 AM
sgtk2's Avatar
sgtk2
Default Horn Problem
Just bought a 1973, horn doesn't work....I press the button and I hear a click sound like a reply just activated. Release the button and another click. Suggestions?
Old Sep 15, 2010 | 11:47 AM
joewill's Avatar
joewill
test your horns. unplug the wire to the horn and look for 12 volts when you press the horn button. run a jumper wire from the battery to the horn terminal on the horn itself see if it blows.
the click means your horn relay is kicking off, but now you need to see if it is sending current down the wire to the horn and see if the horns themselves are bad. also, plug a known good horn into the wire and see of it works..
of course make sure all is grounded correctly also.
Old Sep 15, 2010 | 11:50 AM
BBCorv70's Avatar
BBCorv70
the click means your horn relay is kicking off, but now you need to see if it is sending current down the wrire to the horn and see if the horns themselves are bad. aslo, plug a known good horn into the wire and see of it works..
Could be the horns are bad. I had to replace mine recently, seem to have died while sitting for a long time. Some vendors will rebuild them.
Others offer reproductions or replacements.
Old Sep 15, 2010 | 12:02 PM
sgtk2's Avatar
sgtk2
Thanks for the ideas!! you guys are awesome.
Old Sep 15, 2010 | 02:59 PM
Timsride's Avatar
Timsride
Your horn or horns if You got the 2nd in option is or are dead.Mine did exact same thing, replaced horn no its fine.
To Horn Problem
