Carb help?
Old Sep 20, 2010 | 08:13 AM
96LT4's Avatar
96LT4
Former Moderator
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
CI3 Car Show Winner
Default Carb help?
Hi guys! I bought a 1969 Camaro RS/SS 427 convertible about a month ago, and wondering what the best after market carb is for the car. It is not a #'s matching car, so I'm not worried about originality.
Thank you for the advice in advance!
Old Sep 20, 2010 | 12:10 PM
markdtn's Avatar
markdtn
I guess you know there is no such thing as an SS427 Camaro-unless you have a Yenko or similar.
What carb is on there now?
Old Sep 20, 2010 | 04:47 PM
96LT4's Avatar
96LT4
Former Moderator
Cruise-In V Veteran
CI3 Car Show Winner
Yes, I knew that when I bought it, but it does have a 427 in it now.
The motor is a date code correct 69 block with stock internals. It has an Edelbrock carb on it now, 750 CFM.
Old Sep 20, 2010 | 05:02 PM
GD70's Avatar
GD70
Does it run well? I guess I'm wondering why you're asking?
Glenn
Old Sep 21, 2010 | 07:51 AM
96LT4's Avatar
96LT4
Former Moderator
Cruise-In V Veteran
CI3 Car Show Winner
It idles fine, but doesn't have the power a big block should. It kind of stumbles when you get on it, and the gas mileage sucks...less than 3 MPG right now.
The carb is a 750 CFM according to the paperwork I have.
Old Sep 22, 2010 | 08:00 AM
markdtn's Avatar
markdtn
Nice looking car. Are you sure the fuel pump is good and the lines aren't clogged or the sock stopped up? I had a 71 Eldorado once. Idled great, putted around the yard fine, but when you got out on the road it fell on it's face. Turns out there was a restriction in the fuel sender line that it couldn't get enough fuel. I would make sure it is getting fuel. Past that, I don't know much about Edelbrock carbs. Perhaps someone will chime in with an adjustment proceedure. If that doesn't work and it was me, I would go with a Holley 750.
Old Sep 22, 2010 | 11:01 AM
96LT4's Avatar
96LT4
Former Moderator
Cruise-In V Veteran
CI3 Car Show Winner
I'm taking her to a local guy later this week and we'll check that out for sure. Thank you for the advice and kidn words.
To Carb help?
