Hood
Old Sep 21, 2010 | 11:38 AM
Raffman's Avatar
Raffman
Default Hood
Does any one know how to line up the front of my hood, 78 vette, I have the sides lined up but the front is still sagging probably 1/4 inch
Spoiler
Old Sep 21, 2010 | 12:15 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Which is low? The hood surround panel or the front of the hood?
Old Sep 21, 2010 | 12:16 PM
mysixtynine's Avatar
mysixtynine
If the hood is below the nose at the furthest most point then you need to put some shims under your hood hinges where they meet the inner fender wells. If the hood is too high for the nose then you have bigger issues.
I ran into the later with the aftermarket L88 hoods. Seems most of them are too high in the front. I had to cut the hinges down and re-weld them together. Then I wound up having to put shims under them as the cutting took off more than I wanted but I've got it nice and flush now.
Old Sep 21, 2010 | 12:29 PM
Raffman's Avatar
Raffman
the front of the hood, what is the surround sound thingy
Old Sep 21, 2010 | 12:54 PM
Easy Mike's Avatar
Easy Mike
Are you using the stock hood?
Old Sep 21, 2010 | 12:58 PM
Raffman's Avatar
Raffman
yes
Old Sep 21, 2010 | 01:02 PM
Easy Mike's Avatar
Easy Mike
Have you had the hood off the car? Has the hood always been low at the front?
Old Sep 21, 2010 | 01:32 PM
Raffman's Avatar
Raffman
the hood was off when they restored the car
Old Sep 21, 2010 | 02:18 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by Raffman
...the hood was off when they restored the car...
Who is "they"? If you have paid for recent work/restoration, return the car to the shop and have them fit the hood.
You can shim the hood hinges on the fender skirts, but that is not likely to get the 1/4" you are looking for. There is a reinforcement bar under the nose running from the front of the radiator support to a point behind the front bumper. Tweaking the bar will lower the hood surround panel toward the edge of your hood.
Getting the two panels to meet might require a little of both.
Old Sep 22, 2010 | 07:00 AM
Raffman's Avatar
Raffman
Thanks E Mike, I'll let you know how it goes
Old Sep 22, 2010 | 11:02 AM
Easy Mike's Avatar
Easy Mike
Go slowly. A little tweak can mean a lot.
Old Sep 22, 2010 | 01:29 PM
Raffman's Avatar
Raffman
Well, after a little investigation I noticed that the body came away from support, now what would i use to reattach, would epoxy work
Old Sep 22, 2010 | 02:31 PM
Easy Mike's Avatar
Easy Mike
Epoxy will work.
Old Sep 22, 2010 | 03:01 PM
Raffman's Avatar
Raffman
Easy, sorry to be a pain in the ***, but is there a certain type of epoxy!!
Old Sep 22, 2010 | 03:05 PM
Gilded_Splinters's Avatar
Gilded_Splinters
I like the West System products myself.
You can usually grab some at any local marine store or check out their website. Either of these places will also contain lots of info of which resin/hardener/filler combination to use for your specific situation.
Old Sep 22, 2010 | 03:15 PM
Raffman's Avatar
Raffman
Thank you
Old Sep 23, 2010 | 02:02 PM
Raffman's Avatar
Raffman
it's holding for now, Thanks guys and it lines up perfect...
To Hood
