Floppy Mirror
Old Sep 22, 2010 | 06:41 PM
croaker's Avatar
croaker
Default Floppy Mirror
Does anyone have the link to the jb weld repair for floppy chrome side mirrors I searched no luck
Old Sep 22, 2010 | 07:44 PM
GD70's Avatar
GD70
Here you go.
Glenn
http://forums.corvetteforum.com/c3-g...oday-pics.html
Old Sep 22, 2010 | 07:59 PM
7T1vette's Avatar
7T1vette
Basically, you stick the mirror (facedown) in a pan of gasoline or mineral spirits and leave it overnight. That dislodges the glue. You need to make a couple of thin [non-rusting] sheet metal shims to stick under the swedged retaining heads to tighten stuff up. Then put mirror face back on with RTV (do this with face down...if you do it the other way, the mirror will warp a bit due to its own weight and the reflection will be distorted).
If this is for the right-side mirror, you might want to consider getting a newer (and a bit larger) mirror from a junk yard, then cutting it down to the correct size. That will give you a 'bubble' mirror which is MUCH better to see with.
Old Sep 22, 2010 | 08:42 PM
croaker's Avatar
croaker
Thanks guys I had done this when I first got my car and couldn't remember the details. I had replied to that exact post. Thanks again guys
Old Sep 22, 2010 | 08:48 PM
vettes4evr's Avatar
vettes4evr
I read the tip on here recently about using a $4 pressure pin punch on the ball of the base. It took me all of 30 seconds and worked GREAT! I just used it on the ball at 3 or 4 different spots, under where the mirror would swivel on top of it. It's been wind tested up to 75 mph so far and it holds tight.
To Floppy Mirror
