Tall Style Valve Covers
Old Sep 27, 2010 | 10:44 PM
Tim81's Avatar
Tim81
Default Tall Style Valve Covers
I am thinking about putting some tall style valve covers on my 81. What if any issue might I run into?...Thanks Tim
Old Sep 27, 2010 | 11:02 PM
rcread's Avatar
rcread
They might be made from a radioactive element that causes you to morph into a zombie. It's unlikely, but you've been warned.
Old Sep 27, 2010 | 11:25 PM
Roughrider's Avatar
Roughrider
Depending on how the upper radiator hose is routed, it could create some interference with that hose. Outside of that, I can't think of any issues you might run into.
Old Sep 27, 2010 | 11:37 PM
Birdman's Avatar
Birdman
You'll have more surface area to clean and polish...?
Old Sep 28, 2010 | 12:12 AM
redman76's Avatar
redman76
St. Jude Donor '09
You may have problems with the alt arm. I had to use some Summit alternator brackets to get my setup working. You'll at least have to get a longer belt. Before you order any parts, make sure you put the VCs on and see if current bracket/belt works, measure, then order what you need. That was the only issue I had.
Old Sep 28, 2010 | 06:47 AM
Roco71's Avatar
Roco71
On my 71 I had to use a longer alternator belt. I was already using a 75 bracket because of headers.
Old Sep 28, 2010 | 10:02 AM
thegazman's Avatar
thegazman
Default thegazman
Tall valve covers on a 79. No problems.
Old Sep 28, 2010 | 10:41 AM
MrJlr's Avatar
MrJlr
You HAVE been warned !
Old Sep 28, 2010 | 11:45 AM
75+78 Corvettes's Avatar
75+78 Corvettes
I had issues with the alternator and the AC compressor. with the compressor, there is almost no room on my 75. Got M/T finned aluminum covers
Old Sep 28, 2010 | 11:54 AM
tonak's Avatar
tonak
If you have a more or less stock motor with accessories, you won't be able to just switch to tall covers and bolt them on.
Old Sep 28, 2010 | 06:07 PM
Tim81's Avatar
Tim81
Good Info once again from CF members...Thanks Tim
To Tall Style Valve Covers
