Door hinge problem
Old Sep 28, 2010 | 10:22 AM
JasonC3's Avatar
JasonC3
Default Door hinge problem
Hello,
The passenger door on my recently aquired '76 sags - which makes it rub when you go to open it. After searching the net, I am able to find a lot of information about the hinge spring (S shaped one) but not a lot of information about the hinge or replacement of the hinge itself.
My S shaped spring is also broken...part of it is still hooked in the spring and part of it was laying down below. I doubt that the spring has anything to do with the sag, though.
Is there any adjustment I can make or should I just replace the whole hinge, including the S spring? Thanks.
Old Sep 28, 2010 | 02:10 PM
Makonut's Avatar
Makonut
You can get a reconditioned hinge for 65.00 plus a 25.00 core charge or so. A new one for about 160.00. or you can get a pin and bushing repair kit for about 14.00 plus 8.00 for the new spring. All depends on how the hinge body looks and how much money you want to spend.
Old Sep 28, 2010 | 02:19 PM
JasonC3's Avatar
JasonC3
Thanks for the info.
I would be open to trying the repair kit. Any idea how hard the install is? Any special tools required? Do the kits come with any instructions? Thanks again.
Old Sep 29, 2010 | 05:33 AM
Makonut's Avatar
Makonut
Try here. Also is a member here. I am sure they can answer all your questions. My brother did it. Was fairly easy but he is a MB,Porche,BMW mechanic.
http://willcoxcorvette.com/advanced_...s=door%20hinge
To Door hinge problem
