headlight question on a 1977
Old Oct 1, 2010 | 07:41 AM
cst0215's Avatar
cst0215
8th Gear
Default headlight question on a 1977
Hello
I have a 1977 C3.
I notices that when I tunr on the high beam headlights the low beams get brighter, but the other two headlights don't turn on.
I'm hoping this is just a fuse issue, but maybe somebody here could point me in the right direction?
Thanks for any and all help
Old Oct 1, 2010 | 08:13 AM
woodvette03's Avatar
woodvette03
do you have the correct lights installed? high beam for inner, low for outer?
Old Oct 1, 2010 | 08:26 AM
'75's Avatar
'75
I could be that both the hi beams are burnt out, or have corroded connectors.
Old Oct 1, 2010 | 09:19 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by cst0215
...I'm hoping this is just a fuse issue...
If your low beams are working correctly, the fuse is fine.
To headlight question on a 1977
