Cannot close door
Old Oct 1, 2010 | 10:30 PM
davidbr93's Avatar
davidbr93
Default Cannot close door
This sounds silly but last night the passenger side door on my 77 c3 ceased latching when I shut the door. The latch mechanism seems to work - i can push down on it with a screwdriver and latch it similar to how it would latch had it hit the striker if the door had closed. It unlatches without problem when I use either the outside or inside door handle. But if I shut it against the striker it will not latch. Anyone else see this before? Thanks!
Dave
Old Oct 1, 2010 | 11:08 PM
GD70's Avatar
GD70
This happened to me. Remove the interior door trim to access the mechanism. Give it a good cleaning & relube. Mine work perfectly now. You may need to remove the whole thing if it's really gummed up with old grease & grime.
Glenn
Old Oct 1, 2010 | 11:17 PM
davidbr93's Avatar
davidbr93
Thanks for the response! I tried some spay lithium grease but that didn't help. I'll try the removal and cleanup this weekend.
Old Oct 2, 2010 | 03:14 AM
eidnolB's Avatar
eidnolB
Cruising
Same thing happened to me on my 75. But an adjustment was needed?
To Cannot close door
