door panel trim
Old Oct 3, 2010 | 11:30 PM
Skip Burney's Avatar
Skip Burney
Default door panel trim
I`m attaching the trim to my new door panels and was wondering what do you use to attach the trim pieces that are riveted to the door panels. I am guessing that I need to grind the small rivets off from the back side and use something to reattach the trim piece with.
Old Oct 3, 2010 | 11:45 PM
7T1vette's Avatar
7T1vette
I used a Dremel to grind/cut the [swedged] heads off those pins; then just used 2-part epoxy to created a new 'head' on the ends of those pins when I transferred it to the new panel. It's been that way for 5+ years with no problem.
Old Oct 4, 2010 | 12:09 AM
Skip Burney
Thats the deal thanks I may slip a washer over the pin and epoxy it on there. Thats why I love this forum. I had to take 4 weeks away from the car to have spinal fusion surgery on my neck and I am really glad to be back on the car again
Old Oct 4, 2010 | 10:57 AM
7T1vette's Avatar
7T1vette
If you are back working on the car that quickly, you must be doing well on your recovery. Congrats on the successful surgery! Just take it slowly at first...don't overdo it.
Old Oct 6, 2010 | 10:49 AM
buckNeccid's Avatar
buckNeccid
St. Jude Donor '11
What they said SKip, take it easy afterward. I had mine, and felt wonderful till I went back to work and bumped my head standing up too quickly under a rail car. Most of my problems have returned and they say there isn't anything showing to cause it. Make sure you continue the therapy exercises, they do help.
Old Oct 6, 2010 | 11:32 AM
75+78 Corvettes's Avatar
75+78 Corvettes
A dab of JB weld on the end of the pit would be sufficient
Old Oct 7, 2010 | 01:14 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
This might save you some time too... http://willcoxcorvette.com/repairand...lp.php?hID=113
Old Oct 7, 2010 | 10:13 PM
Skip Burney
Thanks a bunch guys they fused c-4, c-5 and c-6 and used a cage and screws. I was really sore for about 2 weeks but now I only have a zinger or two a day down my arms and they are gettins less and less. Have to wear some sort of bone stimulator for a couple of months but it is a thousand percent better. I have no idea how it happened I just woke up one morning in agony.
To door panel trim
