Clock Installation
Old Oct 4, 2010 | 01:12 PM
corvettecurt's Avatar
corvettecurt
4th Gear
Default Clock Installation
Just bought an AC Delco quartz clock for my '81. Are there any installation instructions availible for it?
Old Oct 4, 2010 | 03:33 PM
thegazman's Avatar
thegazman
Default thegazman
Just remove the center gauge surround bezel (cluster). Use good mechanical judgement to remove the old clock and install new clock in reverse order. Be careful with your printed circuit. Reinstall gauge bezel into dash opening. If it resists, don't force it. Be sure the A/C duct is properly inserted into back of the bezel.
Old Oct 4, 2010 | 10:24 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
At the link below you'll find instructions on the dash pad removal. In this is a section on how to remove the center dash cluster.
Once the cluster is out it's simple.. just remove the front adjusting **** by using a small screw driver, then remove nut on the back of the clock that pinches the printed circuit and then remove the three bolts that hold the clock to the bezel. That's it.. reverse and you've got it! http://willcoxcorvette.com/repairand...lp.php?hID=263
Willcox
To Clock Installation
