Early/Late
Old Oct 8, 2010 | 08:39 AM
Bond007's Avatar
Bond007
Default Early/Late
Hello Fellow Vetteheads,
What is considered a Early or Late vin number for
the 1976 Vette?
Thank You
Old Oct 8, 2010 | 09:12 AM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
Originally Posted by bond007
hello fellow vetteheads,
what is considered a early or late vin number for
the 1976 vette?
Thank you
look here >>> www.c3registry.com
Old Oct 8, 2010 | 09:55 AM
Bond007's Avatar
Bond007
427SIXPACK
You are one smart vettehead..... Thank You....
one piggy back here did you have a chance to read my last post about my broken dip stick?? I have been driving for about two months like this but plan on taking a trip tomarrow and am a little concerned about it causing a problem do you have an opinion on the subject? That is why I needed to know about the year as I have to order a new one.
Old Oct 8, 2010 | 10:22 AM
Mike Ward's Avatar
Mike Ward
Knowing the date of manufacture only partially helps in knowing whether a car has an 'early' or 'late' style of part on it. Some parts changed over in the first few weeks, some at the very end of production.
Old Oct 8, 2010 | 12:43 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
For 76s, early and late usually applies to whether the car had the A6 AC compressor or the new R4. A running change to the R4 was made in the spring of 76.
Old Oct 8, 2010 | 08:07 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Check the upper radiator hose outlet, if its pointing straight then its a early '76, if its pointing upwards then its a late '76.
Old Oct 16, 2010 | 07:58 PM
Bond007's Avatar
Bond007
Finally got the dip stick today from Chevy dealer put it in and the oil came almost half the way up the stick??? The Vin number says it is a late production model so I bought the longer stick 20" as said was needed for this production run. It is obviously too long will have to order the 17 5/16" confused What am I overlooking, or am I mentally light on the matter?
Old Oct 16, 2010 | 08:09 PM
SEVNT6's Avatar
SEVNT6
Mine was built on 4/29/76........sounds late right? But it has the early A6 AC, and most of the time I use early parts.......
Like a 17" dipstick.........
Old Oct 16, 2010 | 08:24 PM
Denpo's Avatar
Denpo
Crazy, the birthday generator tells me the very same thing. What are your five last number? Mine is 32555. '76 Bro indeed
Old Oct 16, 2010 | 08:39 PM
SEVNT6's Avatar
SEVNT6
32597.......just 42 apart! Cool..............
Old Oct 16, 2010 | 08:49 PM
Bond007's Avatar
Bond007
Mine is 38448??? generator says June 76 approx. However I have the
A6 AC ?????
Old Oct 16, 2010 | 08:58 PM
SEVNT6's Avatar
SEVNT6
You're right on the edge Bond. My neighbor has a '76 built in late June, and his has the R4.........
Old Oct 16, 2010 | 09:48 PM
Bond007's Avatar
Bond007
I'll just order the shorter one and will probably have to eat the
the other one.. Thank You everyone appreciate it.
Old Oct 16, 2010 | 10:18 PM
relic1864's Avatar
relic1864
Default early or late
If you really want to know if the car is early or late just check out the fan shroud.....If you are unlucky like I was you have the $1200.00 dollar one then the car is considered early. If its the $200.00 dollar fan shroud then the car is late.
Old Oct 16, 2010 | 10:19 PM
Bond007's Avatar
Bond007
How would I know the difference?
Old Oct 16, 2010 | 10:27 PM
relic1864's Avatar
relic1864
All I know is my shroud had been cut in two for some reason. I needed to get the radiator repaired and told the guy to put a new fan shroud on since mine was cut. He tried putting on the $200.00 fan shroud but it would not fit saying mine was the expensive early one. I just had him epoxy mine back togeather. To me they look pretty much the same just fit on differently. Maybe someone else on the forum can tell you what the difference is.
Old Oct 16, 2010 | 10:52 PM
SEVNT6's Avatar
SEVNT6
Late means all '77. Radiator, shroud, upper brackets, support, hoses....it goes on and on.....
Now........a $1200.00 shroud? CC sells the early shroud for $169.00 The late one sells for $399.00...
To Early/Late
Old Oct 16, 2010 | 11:25 PM
SEVNT6's Avatar
SEVNT6
Also.......do you guys know how to read your trim tab? It's pretty simple..
'76 production started in Aug. '75. In the upper right corner of the tab you'll see a letter & a number. The letter is the month it was built. Aug. was A, Sept. B and so on. The number is the day it was built. Mine is I 29....April 29th. May is J....June K......
Old Oct 16, 2010 | 11:30 PM
Bond007's Avatar
Bond007
SEVNT6
Thanks for all the help will look it up in
the morning.
Old Oct 17, 2010 | 11:06 AM
Bond007's Avatar
Bond007
Checked the drivers door where the tire sticker is and
it clearly has 06/76 on the sticker with the Vin number
just above it. The dip stick is still to long?? Thank again ALL
