Speedo Gear
Old Oct 10, 2010 | 02:26 PM
Raffman's Avatar
Raffman
Default Speedo Gear
Can anyone help me, My speedo is off by 20km p/h, I have a M-21 with a 3.70 rear, can some one tell me where and which Speedo Gear I have to purchase
Thank you
Randy
Old Oct 10, 2010 | 02:59 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
http://www.stl-vettes.com/65Vette/GearCalc.htm
Old Oct 10, 2010 | 05:02 PM
joewill's Avatar
joewill
20 kph too fast or too slow?
Old Oct 10, 2010 | 08:25 PM
Raffman's Avatar
Raffman
if I'm going 100kms, speedo is going 120kms
Old Oct 10, 2010 | 08:35 PM
joewill's Avatar
joewill
then your speedo cable is spinning too fast.. you need to slow it down by replacing the existing driven gear by one with more teeth. 1st find out what you have, pull your speedo cable from the tranny and remove the speedo drivien gear housing. in it should be a plastic gear. count it's teeth and buy a new one with more teeth. .( probably buy 2 or 3.. get one each with 1 more tooth, next with 2, next with 3..) each will drop your speedo by a slight amout. play with it and swap them out until you get real close.
you can get them fairly cheap so buy 3 sizes to play with the calibration.
Old Oct 11, 2010 | 02:35 AM
avner's Avatar
avner
Thank you
Randy
We need to know if it's manual or auto & the rear tire size.
You can also buy a reducer - Speedometer Gear Ratio Adapter, and put it on the cable insert on the trans' - more expensive.
Avner
Old Oct 11, 2010 | 01:02 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
if you look on dr rebuilds site you can see the different toothed gears and their "chart" for determining which gear you need to make the correction. it's a good place to start
To Speedo Gear
