Oil Pressure ?
Old Oct 10, 2010 | 10:13 PM
68vetteman's Avatar
68vetteman
Default Oil Pressure ?
What do you feel the proper oil pressure should be? The old 350 I had required 20/50 oil to get 25 lbs. at idle and 35 lbs at 3000 rpm. (Yes the bearings were shot). I'm running 10/30 in my new 383. It has a stock oil pump. I get 70 lbs + at start up, 35 lbs at idle hot and 65 lbs at 3000 hot. I feel a lot better with the higher oil pressure or this a little on the high side? I could use 5/20 oil to lower the pressure. What do you think? Thanks
68 Vetteman
Old Oct 10, 2010 | 11:28 PM
BBCorv70's Avatar
BBCorv70
Originally Posted by 68vetteman
I get 70 lbs + at start up, 35 lbs at idle hot and 65 lbs at 3000 hot. 68 Vetteman
This sounds like what I get out of my 454, rebuilt, new crank and bearings. etc. I run 10/30.
Old Oct 11, 2010 | 12:32 AM
Skip Burney's Avatar
Skip Burney
I have heard an old rule of thumb is 10 lbs pressure per thousand rpm. Me I have broken thumbs and I like your numbers a lot better. I wouldn`t worry about it at all.
Old Oct 11, 2010 | 01:08 AM
noonie's Avatar
noonie
It would help you to know exactly what pump you have, but if it is a stock Melling m55 (most are) then you most likely have a 60psi relief spring.
Just adjust your oil viscosity, so that the pressure (with accurate gauge)
stays below that pressure for 99% of engine running when at temp and rpm.
Running over relief raises oil temp drastically, and one of the purposes of the oil is to carry heat from the bearings.
Old Oct 11, 2010 | 10:47 AM
7T1vette's Avatar
7T1vette
Unless you drive the car in very cold weather (below 10 deg F), keep 10W30 oil in it. 5W is too thin for warm weather use, IMO.
To Oil Pressure ?
