Tranny conversion
Old Oct 18, 2010 | 03:48 AM
cudabob's Avatar
cudabob
Cruising
Default Tranny conversion
How easy, and what would it cost, to put a TH400 into a 73 Vette with a 4 speed?
Old Oct 18, 2010 | 07:29 AM
markdtn's Avatar
markdtn
Easy-except the crossmember.
Source transmission, Use driveshaft and yoke for any C3 TH400 car, cut out crossmember and convert to removable, source cooler lines-either change radiators to one that has a cooler or use a large external cooler, source shifter and shift plate for the inside. Less than $1000 trans and all. You might be able to find someone converting to a stick that would trade with you.
Old Oct 18, 2010 | 09:12 AM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
Unless you already have the 400, why not go with a 200 or 700 with overdrive. Pretty much the same swap conditions and you end up with the OD.
Old Oct 19, 2010 | 02:15 PM
Vette5.5's Avatar
Vette5.5
I agree going with a 700/4L60, as you can get these built up pretty strong, and the 4th gear O.D. w/lock up converter is pretty sweet for highway cruising. I've done this on a few car's and would recommend going a 4L60E electronic, as aftermarket computer controller's are quite reasonable now. A lot easier to program shift point's/lock up than playing with mechanical linkages and external switches on the older style unit's.
Old Oct 19, 2010 | 05:02 PM
PRNDL's Avatar
PRNDL
I love a forum where you can start a topic titled "Tranny conversion" and nobody makes a snide comment!
Old Oct 19, 2010 | 05:20 PM
69ragvette's Avatar
69ragvette
Default trans
pulled a 1974 454 and a 400 turbo trans out of my 69 had to change yoke remove trans lines and I put a 4 spd in
Old Oct 20, 2010 | 02:51 AM
cudabob's Avatar
cudabob
Cruising
Is Source transmission a business? Where are they located? Or by source do you mean locate?
Old Oct 20, 2010 | 03:02 AM
Peterbuilt's Avatar
Peterbuilt
Originally Posted by cudabob
By source do you mean locate?
Yes! As in junkyard or from somewhere.
Old Oct 20, 2010 | 04:39 AM
cudabob's Avatar
cudabob
Cruising
Thanks, because I found a Source Transmission on the web in California.
To Tranny conversion
