I need to rebuild the headlights. I would like to remove the front "bumper" and take them out through there.
Will that work? I hate to go to all the trouble of taking off the front bumper and then find out - oops, you have to go out through the radiator side...
udornf4, need to remove them through the headlight openings where they sit. Get a AIM or GM dealer repair manual which is good. I've never heard or removed them through bumper opening. I wouldn't remove the bumper. Thanks
sgm
They won't remove through the top. They have side mounts inside that prevent that. I already tried that. Perhaps I missed something, though.
I'll take a look at removing through the bottom. Actually, I didn't look at that option.
i couldn't remove the lights thru the opening , or the grille-unless the light was "collapsed". by that i mean the four springs were removed and the pivot bar they attach to is removed. that allows the operating mechanism to fold up and reduce the height of the unit. it will then slide out without any problem.
thanks to all
they can be installed through the top i have done it before. its best if u take the hood and radiator out and install it through the engine compartment
What he said^
If you feel the need for a challenge, let me tell you to put multiple layers of masking tape around the openings. The horseshoe can scratch the heck out of the paint without even trying. (Ask me how I know)
thanks to all
WELL I I had to replace the RF headlight door on my 75 a few years ago and I removed it and reistalled it from the top. To remove from the top you have to unhook all wires, springs, and levers. Prop the door open use a allen wrench loose the allen screws then lossen pivot pin. Shift pins out of the way and TADA light assembly comes right out. Reinstall by reversing this process. I'm not on any drugs by the way, worked for me. Thanks
Remove and install from the bottom. My advice is not to try to fish them through from the top side.
Good advice on purchasing the AIM and the chassis service manual.
I just removed both from my 73 and I went out the bottom. Granted, I have no reason to protect my paint (yet) because we're on the "disassembly" side of the restoration. I chose to go out the bottom for two reasons, 1) gravity was on my side as I was working alone. 2) given the size and shape of the headlight support frame itself it just didn't seem worthwhile to try and fish it up through a smaller, rectangular hole.
sgm
This sounds like a viable option too...when I went out the bottom with mine I was removing the entire assembly. If you leave the support framework in place and pull the headlight at the pivot pins....that works too.
