Everytime Kevin orders a part ...
Old Oct 22, 2010 | 08:18 AM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Originally Posted by Kevin_73
A Ford tranny in a vette? Seriously?
Will that bolt up to the stock bellhousing?
will it use the same design clutch?
What about the slip joint, will it accept the stock u-joint?
Does the driveshaft length have to be changed
Would the floorboard have to be cut to accommodate the shifter?
Yup (but it's not a Ford tranny per se, it's just a Tremec with a Ford bellhousing pattern)
Nope (fab an adapter plate)
Nope (Chevy pressure plate, Ford disc. Works great)
Nope (use the provided tailshaft)
Yup (order a custom driveshaft)
Don't recall if I had to modify the shifter opening. I think I did.
Or spend $3k and get a Keisler kit that's much more of a bolt-in
Old Oct 22, 2010 | 08:59 AM
mrvette's Avatar
mrvette
Originally Posted by ddecart
Hey Liz! Accidentally order one of these: http://www.summitracing.com/parts/FMS-M-7003-Z/
Wish the hell THAT was available, let alone 1300 bux, back in '97 when I was doing my automatic o/drive from the Muncie....would have liked to keep the stickshift.....
Old Oct 22, 2010 | 02:08 PM
Kneel 8250's Avatar
Kneel 8250
St. Jude Donor '11-'12
Hey Liz !!!!! I have a fully rebuilt 4 speed gearbox in the 73 that looks identical to yours and reverse does work. Only you have to push the car no matter which direction you want to go in.
Have a great day.
Kneel
Old Oct 22, 2010 | 02:37 PM
Tinkerbell_in_Texas's Avatar
Tinkerbell_in_Texas
St. Jude Donor '08-'09-'10-'11-'12, '14
Old Oct 22, 2010 | 02:49 PM
oyealiz's Avatar
oyealiz
2022 C8 of the Year Finalist - Unmodified
CI 3-4-5-6-7-8-9-10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'16
Originally Posted by Tinkerbell_in_Texas
Sounds like Kneel needs to get that car moving under motor power...in any direction!
Old Oct 22, 2010 | 03:08 PM
oyealiz's Avatar
oyealiz
Thinking of spending money, that reminds me that the registrations are out on my c6 and the Wrangler.
It's always something!!!
Old Oct 22, 2010 | 05:09 PM
Paul L's Avatar
Paul L
Well....I always enjoy your posts on OT although I rarely chime in. Get those stickers!
Old Oct 22, 2010 | 05:23 PM
bradc6's Avatar
bradc6
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
National Champs Gators 4 St. Jude '09
I'm sure you'll be glad to get it back on the road. Don't forget the blue tape.
Old Oct 22, 2010 | 05:25 PM
oyealiz's Avatar
oyealiz
Chime in! The more the merrier.
As for the stickers, I need to start driving the c6...she was dead when Kevin tried to move her earlier this week, and I need her legal to drive her, of course!
Did Matth3w whine and have that thread boneyarded?
For the record, I've never blue taped my entire front end, even at the track. But I'm not nearly so picky as some folks, obviously!
Old Oct 22, 2010 | 06:46 PM
Tinkerbell_in_Texas
Now I know what to get you for Xmas!!!!!!! 5 trickle chargers......
Old Oct 23, 2010 | 07:47 AM
NTRBL33's Avatar
NTRBL33
From: The United States of TEXAS www.corvettemotorsportsinc.com
St. Jude Donor '07-'08-'09-'10-'11
ONLY 5?
Old Oct 23, 2010 | 10:10 AM
74 vert's Avatar
74 vert
From: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
Nice looking 68. Glad to see you still have it, and modifying it.
I'm in the middle of a brake redo. Missed two Eastern Tennessee Fall cruises.
Good luck with the Tranny.
Old Oct 23, 2010 | 03:26 PM
  #33
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
I've had her for years.
Good to hear Liz! Glad to see ya moving on getting her back up to driving status.
Old Oct 25, 2010 | 01:56 PM
  #34
oyealiz's Avatar
oyealiz
I need at least four! Surely I can keep SOMETHING running!
Hey!!! Long time, no see! How's the cute kiddo?
Yeah, it's a tad difficult to get her out of the garage with no reverse gear!
Kevin took the transmission totally apart yesterday. He decided on a full rebuild. And now he's talking replacing engine gaskets to get rid of some leaks while he's at it.
Old Oct 25, 2010 | 02:07 PM
  #35
bradc6's Avatar
bradc6
That's another thing mine needs. I think it's the oil pan gasket.
Here it is at Vettes at the Village in San Destin on Saturday. Nice little 150 mile cruise.
Old Oct 25, 2010 | 03:02 PM
  #36
Sigforty's Avatar
Sigforty
Well there is no better time to do it. With the trans out he can get to more of the engine easier.
Old Oct 25, 2010 | 03:22 PM
  #37
Kevin_73's Avatar
Kevin_73
Cruise-In X Veteran
St. Jude Donor '09-'11
Transmission is completely disassembled.
It's hard to say why the reverse was stuck since the reverse selector finally moved while I was ing on it to get the tail housing off.
There is a lot of wear in the reverse shift fork and some corrosion on the boss that rides inside the reverse lever. Other than that it looks pretty good.
The gears all look good, but the synchronizers are all pretty worn, and there is significant wear on the 1-2, 3-4 sliders, along with a pretty good buildup of sludge in the bottom of the case.
I ordered the Super rebuild kit for it (all new bearings, syncros, gaskets, 1-2, 3-4 sliders, countergear shaft, 1-2. 3-4 shift forks, and gaskets), and a new reverse shift fork.
The muncie should be like new when I am done, and with the new shifter it should shift just like it did from the factory.
I also ordered new o-ring calipers for it today too.
Liz said when she bought Hooters that the brakes were really hard, so she had power brakes installed. I don't know who did the work, but I think all they did was install a booster and call it good.
The brakes on that poor car are pathetic. You have to stand on the pedal to get it to stop, even with power brakes.
I'm sure the calipers and brake lines were bad when she bought it 8 years ago, and have only gotten worse over time.
Hooter should be a lot more fun to drive in a couple of weeks.
To Everytime Kevin orders a part ...
Old Oct 25, 2010 | 04:20 PM
  #38
Sigforty's Avatar
Sigforty
Kevin where did u get the rebuild kit from? I am sure when I open the trans from my 71 up i will need to replace just as much if not more.
Old Oct 25, 2010 | 04:39 PM
  #39
Kevin_73's Avatar
Kevin_73
Cruise-In X Veteran
T&B Transmission and Gear. $208 for the Super rebuild kit. They have gear sets and every part for a Muncie ala carte too. Best prices I was able to find on the interweb.
I'll let you know how the quality looks when it gets here.
Old Oct 25, 2010 | 08:39 PM
  #40
snide's Avatar
snide
CI 4-5-7-8-9-10 Veteran
St. Jude Donor '07 thru '11
Muncie? Oh man, that sucks.
