73 Courtesy Light(s)
Old Oct 22, 2010 | 04:07 PM
udornf4's Avatar
udornf4
Default 73 Courtesy Light(s)
I have a question on the proper location of the Passenger Side Courtesy Light mount. The AIM has it located on the top of the kick panel. Can any '73 owner confirm that location?
Mine is screwed into the A/C plenum - about middle of the passenger side (hidden behind the map pocket assy, of course). Just below the A/C ducting...
Old Oct 22, 2010 | 04:55 PM
TOM65 L76 96 LT1's Avatar
TOM65 L76 96 LT1
Will check my 73 when I get home but I believe the light comes on behind the kick panel.
Old Oct 22, 2010 | 05:11 PM
Blue73Shark's Avatar
Blue73Shark
My 73 location matches yours.
Old Oct 22, 2010 | 08:20 PM
TOM65 L76 96 LT1
I was wrong, mine is also located under the dash about in the middle of the map pocket.
Old Oct 23, 2010 | 09:33 AM
udornf4's Avatar
udornf4
Default thanks!
OK, Great!
thanks, guys!
Old Oct 23, 2010 | 11:37 AM
oldsarge's Avatar
oldsarge
I have installed mine as per the manual, which I believe is on top int the middle of the kick panel.
Old Oct 23, 2010 | 11:58 AM
rydoc's Avatar
rydoc
This is a kick panel out of a "73". I circled the spot were the light goes.
Rod
Old Oct 23, 2010 | 11:59 AM
sgm2004's Avatar
sgm2004
same here
sgm
To 73 Courtesy Light(s)
