Are those trailing arm salvageable?
Here's the TA I pulled from my vette (half of it has been treated by electrolysis).
Turns out the rust have done a fair amount of damage to them.
A loft of seams have swelled badly.
Here, all the welding point vanished, leaving a hefty gap that goes all the way thru
Some more swelling
I'm facing a dilemma, I planned installing johnny joints and having the arms welded properly (point weld, no thanks). Do you think those are salvageable of I should I start off with better used arms?
Did I told you I'm on a budget? a tight one.
I'm having the same thoughts about my spindle flange, I could clean them, but they are so pitted I'm wondering if they still have the same structural integrity.
Let me know what you think, did someone repaired TAs in such state?
The seams don't look that bad. All the weldings are still intact. I saw worse where the welds already started cracking due to corrosion under the seams and the car still drove and probably still does.
Of course is a new pair of arms better, but probably not required.
Rgds. Günther
Andrew
800-442-0335
Good luck
As pointed out by some, sure the TAs have rusted, but mainly at the seams, when dirt get stuck.The metal is still thick and strong.
So I think I'm gonna take the restoration path.
I know new TA would be a good thing, I appreciate your security concerns,
But want the shark back on the road by the spring, it's a short time, and if I start buying what I could restore I'm gonna suck my budget dry and postpone even further.
Those trailing arms weren't welded together very well when they were brand new! A good welder will be able fix those up better than new. He (or she!!) can even grind the welds down and make 'em look pretty, but it's gonna cost more than 20 bucks! Use a reputable welder, don't let your brother-in-law who just bought a welder practice on 'em!
Scott
You just lost the game!!!
My bad I should have closed the subject with a final update:
I did contact a couple of professional welders. Since you can't weld on rust, they needed to be blasted.
Cost of Blasting+welding, I was way beyond the price of good used, even shipped to Canada.
So I bought a pair from a forum member.
Since the game have changed, I now have access to a blasting booth and a MIG for beer money (thank Michel!).
So I used that welder time to put some Johnny Joint move the cable bracket.
I'm keeping the old ones as playground for wilder mods.....
Just a slight tangent: why Johnny-joints for the trailing-arm pivot? I know they're used for links off-roading where you want maximum articulation and resistance to deflection. I would think the only motion you want in the trailing-arm pivot is in the vertical plane, with *resistance* to motion in any other plane?
John
