block casting number
Old Oct 27, 2010 | 06:31 PM
Skip Burney's Avatar
Skip Burney
Default block casting number
I am getting ready to build a 388 for my 72 and I am looking at a 350 a guy near me has that I can get. It is a 4 bolt main block and the engine supposedly came out of an 82 Caprice. It has a quadrajet intake on it and the block casting number is 3970810, can anyone tell me what size valves are in this thing I don`t want to buy it if it has small valves but I don`t want to take the heads off it at his place.
Old Oct 27, 2010 | 07:49 PM
Mike Ward's Avatar
Mike Ward
You sure about that number? Might be 3970010. What's the information on the engine stamp pad.
Old Oct 27, 2010 | 08:08 PM
Skip Burney
what would it be if it were a zero Mike. the engine is lying on it`s side in his garage and is pretty nasty. I could have easily missed a number
Old Oct 27, 2010 | 08:22 PM
Mike Ward's Avatar
Mike Ward
If it's a 0010 block, it's the most common and longest lived casting number of any modern SBC. There's a bazillion of them around. I wouldn't count on this one being anything special. '82 and Caprice doesn't say high performance to me. I'm not even sure they has 350 cu in engines in them, maybe a 305.
Old Oct 27, 2010 | 08:31 PM
garage-ghost's Avatar
garage-ghost
Must be a 3970010. Used from 69-79 in cars, trucks and Corvettes.
You're going to have to get the numbers right in front of the right side head to tell anything else.
Old Oct 27, 2010 | 08:41 PM
Skip Burney
I will get it tomorrow, my main concern is the size of the valves. I pulled the pan off and it is a 4 bolt block but I don`t want to get it just for that.
Old Oct 28, 2010 | 06:08 AM
joewill's Avatar
joewill
get us those numbers but also need head casting numbers and dates and we might be able to tell you the valve sizes.. these will be of course educated guesses since who knows if the heads came with the block.. only way to know for sure is to pull the heads. are you sure it is a 4 bolt main?
Old Oct 28, 2010 | 06:06 PM
Skip Burney
Hey guys the number on the front pad is M-0306-TDR. I know that the M is mexico and the 0306 is the date of manufacture but what doe the TDR stand for. Thanks Skip
Old Oct 28, 2010 | 07:00 PM
Mike Ward's Avatar
Mike Ward
Low perf truck engine. That explains the four bolt.
Old Oct 28, 2010 | 10:20 PM
Indiancreek's Avatar
Indiancreek
Doesn't matter size valves are in it. You can have it machined to a larger size valve if you like. I'd go with the 1.94 intake and 1.60 exhaust unless you'll be spending a bunch of time in the 6,000 rpm and up range. Then maybe I'd go with a 2.02 intake. But under most driving situations on the street you won;t be spending much time in that range.
All sorts of things you can do to help those heads before you install them.
Old Oct 29, 2010 | 01:26 AM
Skip Burney
I was thinking about that today I can go with small valve heads because of the small combustion chambers. I was thinking of around a 10 to 1 ratio and good gas for a street engine
To block casting number
