Hello I just bought a 1970 Corvette and I’m would like to know if I could drive up car ramps without damaging anything..
Shouldn't be a problem. Make sure you really shove them under the tires before you start to drive up them. They may slide as you attempt this.
I do it quite often.
Glenn
Welcome to the forum, and congrats on your new purchase. Not a problem, to drive up a ramp, also make sure you have clearance while you are going up the ramp. If you feel it might be too steep, and will bottom out, you can put some heavy wooden planks under to lessen the slope.
BE FORWARNED! Never just a jack under that piece of sheet metal under the front center of the car. Yes, you'll lift the car..., as you dent in the metal. My father-in-law did this to mine when we first got it.
Congratulation! When you have a chance your more then welcome to submit photos of your car including but not limited to front, sides, rear, engine bay, interior, under the car shots and a little history about the car if possible. LOL
By the way, Welcome to the forum.
GG
Race Ramps are specifically designed for low ground clearance cars. Our 56" and XT ramps provide a 10 degree angle of approach, so the nose doesn't scrape as the car goes up the ramps. They are made with a solid block construction that is strong, and yet very lightweight. As well, the ramps have a grippy coating - so they won't slide. Even on epoxy coated floors.
