manual to power window conversion?
Old Oct 31, 2010 | 10:15 PM
Crush2's Avatar
Crush2
Default manual to power window conversion?
I have a '72 with manual windows, saw the 72-74 Power Window Conversion Kit on Zip. Does anyone have experience doing this conversion, advice, caveats, etc.? Any other conversion kits that are preferable? TIA!
Old Oct 31, 2010 | 10:21 PM
mrvette's Avatar
mrvette
15 years ago, I added the parts needed to my '72 vert....the motor/geartrain parts were common green grass off any junkyard car of the era..GM that is.....the regulator gear set is totally different, so the large sector gear needs replaced I ordered a set of regulators from Yogi Behr IF I recall correctly.....
the window switches and bracket came from carlisle....I cut the holes in the then new console piece....
the wiring is easy, really....mine are run off the main/RED power wire..so they work with ignition off.....
Old Nov 2, 2010 | 08:02 AM
Crush2's Avatar
Crush2
Thanks for the offer, Gene, but I'm keeping all the original parts "just in case". It was a well-maintained and documented car before I got it, and keeping the original DNA is important. Hope you find someone else to swap with! :-)
Old Nov 2, 2010 | 03:40 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The ZIP kit looks pretty complete. Purchase the 72 assembly instruction manual (AIM) and take a look at the factory installation of the optional power windows. The AIM will list and show all the parts you need for the conversion.
Remember: your original interior door panels have holes for the window cranks. PW cars do not have the holes in the panels.
In all likelihood, the underside of your e-brake console will show two squares which you have to open to mount the window switches. Not difficult. The regular e-brake support hardware already has provision for mounting the switches.
Old Nov 4, 2010 | 11:33 PM
Crush2's Avatar
Crush2
Thanks, Mike! I have the '72 AIM, will do as suggested. I will replace the door panels if/when I do this, but I'm saving all the original stuff. It's contagious, you know!
Old Nov 5, 2010 | 09:04 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Crush2, if you do this conversion please lets us know how it goes. I know I am interested in hearing. I want to do this conversion when I get my 71 back on the road.
Old Nov 5, 2010 | 09:41 AM
zwede's Avatar
zwede
The nice thing about PW on a C3 is that the whole thing was a complete afterthought by GM. So the entire wiring for the PW is a separate harness that just ties in at 3 spots, an existing ground on the bird cage, a hot feed from the horn relay, and a spade connector plugged into the ACC terminal in the fuse box.
I'm not familiar with the ZIP kit. I'm converting my '71 right now using original/repro products. I got a new PW harness, as well as switches, relay, etc. The regulators were originals from Ebay. I'm replacing the door panels anyway so I'll just not cut the holes for the cranks. My p-brake console does not have the holes for the switches, but they are marked on the backside so easy to cut.
Overall it's a somewhat involved project labor-vise, but not difficult.
Old Nov 5, 2010 | 11:15 AM
Crush2's Avatar
Crush2
That's good to know, Markus, thanks!
To manual to power window conversion?
