awesome door lock fix discovery
Old Nov 17, 2010 | 01:01 AM
81fastvette's Avatar
81fastvette
Default awesome door lock fix discovery
I made an awesome door lock discovery after 12 years of locking with the key, waiting for the passenger to close the door so I can push the button while I hit the lock switch, replacing lock motors etc... finally I had enough and took a closer look and discovered that if you take a dremmel to the little round spring that holds the lock lever up or down, cut the spring and pull it all out with a pair of needle nose pliers the door locks will work beautifully. I can now lock and unlock the doors every time with the remote, just like other cars JUST like it should be. The spring is NOT necessary as the lock motor will hold the locking lever in the locked and unlocked positions, basically all the spring does it make it difficult for the lock motors to do their job as a result of the resistance. Pull the door panel, buzz the spring and your door locks will work awesome provided your motors and connections are good.
Old Nov 17, 2010 | 02:51 AM
3rd_Vette's Avatar
3rd_Vette
Pictures are worth 1,000,000,000 words.. Did you take any???My door locks suck
Old Nov 17, 2010 | 08:24 AM
...Roger...'s Avatar
...Roger...
Weak door lock actuator action is very often due to one or both switches having high resistance internally. I usually just replace both switches for $20.
Old Nov 17, 2010 | 09:21 AM
PRNDL's Avatar
PRNDL
power door locks... is this C3 general? When did they offer power door locks?
Old Nov 17, 2010 | 11:02 AM
DZRick's Avatar
DZRick
1978 up.
http://www.100megsfree4.com/corvette/1970/vet78.htm
Old Nov 17, 2010 | 02:07 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
standard equipment in the 78 pace car edition and an option for all others that year. certain that it was offered before 78 as an option, but would have to get out my black book to see exactly when.
Old Nov 18, 2010 | 12:32 AM
81fastvette
I didn't take any pics but once you get inside the door and look at the linkage you will see what I am talking about. I am very happy with the fix especially because I have remote controlled door locks, so no more using the key or physically locking the doors.!!!!!!!!
Old Feb 23, 2018 | 11:05 AM
myohpe@gmail.com's Avatar
myohpe@gmail.com
Default It works! Photo.
I know this is a really old thread, but I just found it when looking for a fix on my hard to open/close power locks. This guy's fix works really well, because the power lock actuators hold the mechanism in position perfectly. I think many others could benefit from this simple fix. I did it without removing my door panels. I have no anti-theft shields, so I could see the spring in question through the door felts. BTW, here is a photo highlighting the spring which you would remove for this fix.
Old Feb 23, 2018 | 11:30 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
I added remote lock and solenoids to my 69.
makes life much easier with no keys to unlock.
"remote Start to "just because I can .
Old Jan 27, 2020 | 07:30 AM
nearflack's Avatar
nearflack
So glad I found this post. Wish it had been before I paid the price for new latches. I was having same issue after installing new switches, actuators and latches. All I need to do was remove this 2 dollar spring to fix the problem. Locks now worth perfectly. Thanks!!
Old Jan 27, 2020 | 03:27 PM
platinummaker's Avatar
platinummaker
I as well. Easy and cheap mod and appreciated everyday!
Old Jan 27, 2020 | 04:42 PM
Bikespace's Avatar
Bikespace
I'll be trying this!
To awesome door lock fix discovery
