You maybe wont have as much a problem with your car stored outside where everything about it will be cold as the surrounding element's. Critter's are usually more interested in a warmer sheltered garage, or nesting in the nice warm engine compartment of a driven car. If not much other shelter around, could decide on your Vette though. Check with site "bugspray.com" for more information.
I had a Bronco riddled with mice after one Michigan winter. They crawled up under the dash and made nests in the firewall insulation. I didn't prepare to keep them from getting in though as I only used the Bronco to plow the driveway but thought i still used it enough to deter them. Nope! I'm not too fond of mice anyway so I almost burned the thing to the ground to get rid of them. Instead, I sold all of the mice and gave the Bronco away free. And yes I told the new owner.
As 78pace said, dryer sheets has always worked for me but get good name brand ones. I used some cheap dollar store generic ones one time in my shed and the mice ate em.
I've read Irish Spring soap is a good deterent. You would need to have it up off the ground though so it doesn't dissolve from the winter moisture.
Put some inside the car, and in the engine compartment.
Glenn
The only thing that worked a couple of years ago when I had mice in my garage was mouse poison. I haven't seen another one since. You do run the risk of one dying in a very inconvenient place, and decaying there, though. Glue boards, mouse traps and dryer sheets did absolutely nothing.
ive had an irish springs bar sitting under my drivers seat for the last few years. it doesnt actually keep the mice out of the car. instead the mice eat it, then go off and die some place. its kind of win/win, the mice all die, and my car smells nice.
now if i could just do something about the damned chipmunks that decided my wiper bay and intake manifold were good locations to store acorns.
Not much you can do about the engine compartment when the car's stored outdoors! At best you can protect the interior by having it sealed closed and make sure that vents and heater controls are in the closed position. Try to remove all food before closing up!
Have been using Irish Spring for about 5 years now in my holiday trailer which gets stored out at my brother in law's farm every winter......no mice....used it my wife's MG for about the same amount of time and no mice ( this car was prone to mice living in it previously...) Presently have it in my 82' ( so far...no mice...)
I buy about 6 bars....cut shavings off them and put them in small foil tins in the engine bay and inside the car on the floor...
Bonus is in the spring when you take out your car doesn't smell like your grandma's house if you use moth ***** !
Reason: spelling
Take 4 dollar store lasagna tins. Flatten them out on one end, stick one in front of each tire, roll the car until the tires are inside the tins. Re-fold the tin until each tire is in it's own dish.
Throw a dozen mothballs in each one and voila - no critter will climb up into your car (from the ground, anyway)
EDIT/CAVEAT: this will keep mice and small critters out. Bigger / more acrobatic ones (squirrels / raccoons) that don't need to go up via the tires are another story.
Sounds so cool till I think about the water that would stay in the Tins and if you put holes in it your defeating your purpose.
Im suprised no one does what I do :
Feed the wild cats in the neighbor Hood They bring me moles and mice right up to the porch and I trade them for cat food.
You'd be amazed at some of the farmer's 'bulk' mousetraps that can be crafted with simple items. Very ingenious, although not terribly humane.
Have you ever walked into a grainery, lifted a bag of grain and seen a hundred mice scatter? Necessity is the mother of invention. I know of a couple really neat solutions that can capture hundreds of mice in a bucket.
When you're dealing with an infestation, humane is no longer a concern. If I found a colony of mice making their home in my car, sorry - the gloves come off.
Hmmm...is one of them a peanut-butter smeared beer can suspended on a dowel over a bucket of water (or antifreeze depending on the temp)?
I have one of these outside the garage and glue traps inside in case that fails, which is rare.
Scott, I'm not claiming I invented anything
We wouldn't fill the bucket though. We just used those tall white 5 gallon buckets so no jumping out and stuck it beside a bale of hay, for easy access. Once a day, fill it 1/2 way with water, insert a second identical bucket and push down until water squirts-out.
They drown just the same but at least it's quick and not swimming til they're exhausted.
Funny, I was raised on horse farms not far from you (Blackstock Uxbridge). I thought that was a farm thing (high mouse volume), not for you hoidy-toidy Brooklinite city slickers with the occasional squatter...
ever heard of mousetraps?
I tried mousetraps but never caught a single one. They'd steal the bait....occasionally they'd steal the whole trap! Seems we have some pretty sophisticated hoidy-toidy vermin here in the city.
