stupid question
Old Nov 19, 2010 | 01:59 PM
tim bob's Avatar
tim bob
Default stupid question
my 76 has a switch on the side of the center consel near the gas pedal what is that for? thanks
Old Nov 19, 2010 | 02:04 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
I believe that switch is for the rear window defroster. If I am off base, I am sure someone will chime in.
Old Nov 19, 2010 | 02:07 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
i don't believe that was on the side of the console (but like you i certainly could be mistaken). the rear defroster switch (assuming it was even available that model year) should be mounted on the top side of the console in the upper left hand corner. not on the side of the console. it is possible that the OP meant that when he specified "side", but just trying to clarify it. a picture of the switch and it's location would be helpful in determining exactly what it may be.
Old Nov 19, 2010 | 02:15 PM
tim bob's Avatar
tim bob
man you guys are quick i just ran out to look when i hit that switch on top of it is stamped on i see no other switch to turn on rear window defroster
Old Nov 19, 2010 | 02:58 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You are correct and on base. It's the rear window defroster switch or it's a Bubba add on.
SRS244: you are correct for the 77 and later cars.
Old Nov 19, 2010 | 07:45 PM
corvetteload's Avatar
corvetteload
"There are no stupid questions, just stupid people"................Hank Hill
Old Nov 19, 2010 | 08:39 PM
20mercury's Avatar
20mercury
Default defroster switch
I have an early 76, Oct 75, and that is the defroster switch.
Mine has the rear defroster window, but a hole where the switch is supposed to be
Old Nov 19, 2010 | 09:51 PM
shrekviper's Avatar
shrekviper
That's better than a switch and a hole where the window is supposed to be...
Old Nov 20, 2010 | 08:46 AM
20mercury's Avatar
20mercury
Default U Rite!
U Rite!! Normally with any other car, I would worry about having an open window year round, but fortunately my 76 keeps me warm 12 months a year
Old Nov 20, 2010 | 12:01 PM
jordan89's Avatar
jordan89
To stupid question
