74 LS4 PS Pump ???
Old Nov 19, 2010 | 03:25 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Default 74 LS4 PS Pump ???
I will look in my shop manual to double check but does anyone know???
74 LS4 / No factory AC
My PS pump is currently only "powered" by a short belt from the alternator......Should it be from the crank / water pump? That is comparatively a very small drive pulley providing power to the pump.
I've had this car for about 5 years now and it was routed that way when I bought it.
I am wondering if this has slowed the pump rpm's so slow that it does not make the needed hydraulic pressure? I've replaced the pump and valve and it is still a "workout" to drive.
Could this be why my PS requires TWO Hands to drive???
Old Nov 19, 2010 | 05:50 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
...there was a Red/Black Vinyl 43K mile 1974 454 4spd roadster on eBay without A/C from Mershon's that I believe is the same exact way. Don't have link right now.
Old Nov 19, 2010 | 07:50 PM
Tom73's Avatar
Tom73
This is for the '73 LS4 but it should be the same for 74. Believe that yours would be the upper right one.
Edit: having issues with my web site and getting pic to display. So....Should have one belt around the crank, water pump, and PS pump. Then another from the PS Pump driving the alternator. Also a thrid from the water pump to the AIR pump.
Old Nov 19, 2010 | 08:25 PM
Mike Ward's Avatar
Mike Ward
You mean that there's a double pulley on the alternator?
Old Nov 19, 2010 | 08:54 PM
7T1vette's Avatar
7T1vette
No, Mike. The 'single belt' is actually powering the alternator from the P/S pump. His system should have a P/S pump with a double pulley and the main power coming into that system is via the back pulley running from the crank/water pump/P/S pump.
Old Nov 19, 2010 | 09:09 PM
Mike Ward's Avatar
Mike Ward
Originally Posted by 7T1vette
No, Mike. The 'single belt' is actually powering the alternator from the P/S pump..
Yes, but that's not what the OP said. If true, what powers the alternator?
Old Nov 20, 2010 | 12:14 AM
fotyfobravo
Yes...double pulley on alt and pump.
The posted diagram will help me restore to original set up.
Thanks everyone.
Old Nov 20, 2010 | 09:29 AM
Mike Ward's Avatar
Mike Ward
I didn't know double alt pulleys even existed. How about that. I'm not sure that it has much to do with your PS problem though.
Old Nov 20, 2010 | 07:32 PM
mayberg's Avatar
mayberg
...I've replaced the pump and valve and it is still a "workout" to drive.......[/B]
Fred - let us know if it gets any easier after re-routing the belts. You shouldn't need 2 hands to turn. 1.5 should do.
Old Nov 20, 2010 | 07:44 PM
fotyfobravo
I have now....inspected, cleaned and greased every joint in the steering system....replaced the pump....corrected the improper belt routing....replaced the control valve.
It still takes two arms to turn and while I'm not The Hulk, I'm not a weakling.
The only thing I have yet to replace is the hydraulic cylinder.
I am ordering a rebuilt one tomorrow.... I will let you know if that fixes it.
I thought the cylinder would either "work or not",maybe it's just WEAK!
Old Nov 22, 2010 | 09:46 AM
mayberg's Avatar
mayberg
Maybe it's hooked up backwards?
Old Nov 24, 2010 | 12:22 PM
LS4 PILOT's Avatar
LS4 PILOT
Mayberg is right Buddy, you still have aproblem somewhere, my 454 w/PS turns very easy. With a couple fingers if I wanted too. I had my original steering pump rebuilt at BEARS,in PA about 15years ago and just recently restored the valve the pivot was worn. Car never has steered better.
I have the complete original belt system with all the bells and whistles AC, AIR smog system, idle pulley , PS all the correct original GM pulleys still on my car since new...yep its tight fit . It works fine. I use the Quantium,belts , for no reason, other than I kNOW they are the correct lenght and quality and when its all reassembled it works FIRST TIME and adjusts up correctly.
BTW...... I put new pair of coil springs under the front end . MAde a world of difference in handling.
Old Nov 24, 2010 | 01:49 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Check for correct hose routing. As stated, something could be backwards. If not, my guess is, the steering box is seized up.
Also, what's the tire pressure in you tires? It can make some difference.
Lastly, raise the front of the car on jack stands,..crawl under it and watch the steering linkage for binding or interference while a helper turns the steering wheel back and forth.
Good luck!
To 74 LS4 PS Pump ???
