What is the difference between White Lithium Spray vs applied
Old Nov 23, 2010 | 03:20 PM
James B's Avatar
James B
Default What is the difference between White Lithium Spray vs applied
I am working on my corvette door latching mechanism and have removed it so I could clean it really well. When researching here on the forum, people say to apply it instead of spray it in. Why is that?
James
Old Nov 23, 2010 | 04:45 PM
toolman1981's Avatar
toolman1981
James
From what I understand, you don't want to get it on the inside of the outer door skin, may soak into the fiberglass and cause paint issues.
Old Nov 23, 2010 | 05:58 PM
James B's Avatar
James B
So if the locking mechanism is removed from the car then there probably is not going to be an issue.
Thanks for the info.
Jame s
Old Nov 23, 2010 | 08:58 PM
sgm2004's Avatar
sgm2004
Jame s
James not a issue its all inside at least I never had a problem. Sometimes if it gets on glass and sits it does get very hard to remove.
sgm
To What is the difference between White Lithium Spray vs applied
