Exhaust manifold
Old Nov 26, 2010 | 10:02 AM
ED79's Avatar
ED79
Default Exhaust manifold
Right side is cracked 2-3" above the heat riser, 79 stock 350 with a/c. Was wondering if anybody has tried the Dorman replacement manifolds or have a good one for sale? Ed
Old Nov 26, 2010 | 10:57 AM
Binnie77's Avatar
Binnie77
Ed, I have a set of mint original ones off of my '77. These are off a California car with the air tubes in them. Your car may not of had the air pump on it.
Old Nov 26, 2010 | 11:24 AM
LancePearson's Avatar
LancePearson
Zips sells a set of plugs that screw into the exhaust manifolds to plug the air holes if you want to do that. Just steel plugs to block them off. Not expensive either.
Old Nov 26, 2010 | 01:32 PM
killain's Avatar
killain
Oldtimer
Default 79 exhaust
And I have a perfect heat-riser if your going to replace yours. This one has a lever and a ball on the end to lift the exhaust valve once the car is heated up. but it's only good for if your going to bring the car up in the emissions standard.
Old Nov 26, 2010 | 01:59 PM
ED79's Avatar
ED79
Thanks Binnie but mine doesn't have the air tubes or pump so I'll pass. Ed
Old Nov 26, 2010 | 02:02 PM
ED79's Avatar
ED79
That's what I have, will keep you in mind if this goes in that direction, thanks killain, Ed
Old Nov 26, 2010 | 07:11 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
I've got a pair off a 78 L48, no smog holes.
Both sides are actually the same, no. 3932461 RH 17 GM
One has a slightly hogged out hole for one of the 3 flange studs so might just toss that one, other one in excellent condition but you will need to add the 3 studs for the exhaust pipe flange.
$20 + shipping.
I'll even sandblast it
pics if you want.
Old Nov 27, 2010 | 06:41 AM
ED79's Avatar
ED79
$20 + shipping.
pics if you want.
PM sent
Old Nov 27, 2010 | 10:00 AM
mar's Avatar
mar
...that's a terrific deal!
PM sent
Old Nov 27, 2010 | 10:59 AM
ED79's Avatar
ED79
Yea I must be getting on Gods good side hope it goes through. Ed
Old Jul 30, 2025 | 06:00 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
.... oops, wrong thread
To Exhaust manifold
