Looking for a little frame input/experience
Old Nov 30, 2010 | 09:53 PM
runnin empty's Avatar
runnin empty
Default Looking for a little frame input/experience
I was reading a previous thread about jack stands and where to put them and signs of cracking were getting noticed.
This is what I saw on mine-When I pulled the body,totally stripped frame of all moving parts,I noticed the frame had a lot of flex in it-but no rust at any areas of integrity,when on jack stands at all 4 corners,I could lift 1 corner,all others stayed on stands.
Then,I noticed factory welds only about 1 1/4 long every 16 inches or so.
So,I fully welded the frame seams on top and bottom and is now stiff as could be -no flex at all now.
My question is: did I mess up by doing this for value?
The way I figured is if the frame can't flex-leave it up to the suspension to do its job,and the body seams can't crack anymore.
What are the opinions on this-was it good or bad to do?
Strength vs. originality?
Thanks!
Old Nov 30, 2010 | 10:24 PM
Spot Rot's Avatar
Spot Rot
I think you know the answer but I'll say it any way.
If the buyer wants a car that looks original, he'll pass on your car now. But I'm betting your was not a NCRS restoration anyhow.
If you plan to keep it and the welding makes you happy, great.
As to seam cracking, there are many Corvettes with original ski-welded frames that don't crack. If the body work was done competently, the seams won't crack with or without the extra welding in normal use.
Old Nov 30, 2010 | 11:10 PM
runnin empty
I kind of figured on the welding part,what does the NCRS restoration consist of?
Every thing so far has been bought from Ecklers,what else am I also missing?
Thanks!
To Looking for a little frame input/experience
