68 Roadster 427/400 value?
Thanks!
To quote a price tag, you need to give more info, like is it a numbers matching car , do you have paperwork, like tanksticker ?
Also is it a survivor or has it been restored, repainted ?
Colors original ?
To bad it is not a AC car. Tripower AC cars seem to fetch higher prices.Also how good is the steel stuff, like chassis, birdcage etc ?
Price can be anywhere between 15 and 75 K.
Rgds. Günther
A yellow 4 speed convertible sold last January at Mecum Kissimmee for $31,500, with side exhaust. No mention of matching numbers or docs.
A silver auto convertible was bid to $57,000 at the same auction. Claimed to be matching numbers and restored in 2006, with tank sticker.
A blue 4 speed convertible sold in November on E-Bay for $27,100. Very original and unrestored, sitting outside in the desert since 1984. Claimed to be matching numbers.
There is a green 4 speed convertible on E-Bay for $42,500 buy it now. Claimed to be matching numbers and no mention of restoration or meaningful docs.
So right here we have a range of $27k to $62k. Gunther's estimate of $15k to $75k probably describes the current range, from project car to NCRS Top Flight or Bloomington Gold. Where does your car stand in that $60k spread? You need to tell us, more than just a 2+ condition opinion from some appraiser 5 years ago.
There are many 68's that wear 69 parts because many of the 1968 parts are impossible to find. It looks nice from the outside, but lets see under the hood & details of the dash & interior. maybe you can get a shot of the numbers pad on the motor. What is the redline on the tach ?
http://forums.corvetteforum.com/album.php?albumid=14472
Parts have been upgraded from original, to include: floor heat barrier set, leather seats, Pertronix ignition module & coil, aluminum radiator, B & M Supercooler transmission cooler, braided stainless brake lines, aftermarket sound, battery cut-off switch, Dynamax Super-Turbo mufflers, seven blade fan, gas shocks, stainless rally wheel trim rings, inline fuel filter, and others. I have the original fan blade and clutch, telescoping steering column, beauty rings and the right/left half shafts. I have a 3 1/2 page list of parts that were replaced and a stack of receipts for those.
I understand this car is not ready for NCRS judging, and yes, it should hold its value better than an RV. All I am looking for is a realistic expectation of what this car could fetch in today's market - and the best venue to market it (EBay?).
Thanks for your input.
I need to find a better way to photograph my stamp pad and other tight spots - as the pics/numbers are not legible. T0906IO and 18S401782 for the pad. Trim tab is C11 STD 976. The Intake casting number is 3919850. VIN on the pillar is 194678S401782.
What are the big ticket items (as far as numbers/codes) that I need to show via pictures if I decide to put this for auction on EBay or some other site? I know the car is not 100% 'correct' and would take some work to make it show ready - the body panels are not perfectly aligned and the other items you mention. But I think the basics are there - numbers matching big block in excellent condition.
