Power window conversion wire location ?
Old Dec 3, 2010 | 04:58 PM
JNS_71's Avatar
JNS_71
Default Power window conversion wire location ?
Just finished doing the mechanical part of the power window conversion on my 71. “Minimal blood loss”. Could use some advice on where the power lead to the horn relay passes through the fire wall.
Also a trick that worked well to clean the window tracks. Take a plastic tub and pour ¾ of a gallon of lacquer thinner in and let the thinner wash over the channel pieces in the tub. Make sure to remove the channel stops with the rubber ends first although the lacquer thinner did not phase mine. It cleaned off all the old grease in just a few minutes with little elbow grease.
Thanks for any input in advance
