68 front support rods
Old Dec 5, 2010 | 06:51 PM
woodsdesign's Avatar
woodsdesign
Default 68 front support rods
Guys,
I am having trouble figuring out how the front rods bolt in. The assembly manual shows one rod that appears to bolt to the front bumper header to the lower radiator support. It is too long no matter how I try to bolt it up. A pic would be a great help. Also, the AM shows only one rod and Paragon sold me two.
Thanks,
Larry
Old Dec 6, 2010 | 08:56 AM
gbvette62's Avatar
gbvette62
I believe that it bolts to the top of the core support, and runs forward to the front surround reinforcement that's riveted in place behind the bumper.
I don't have a photo of one installed, but I pulled one from the shelf and measured it. The correct rod appears to be 20 1/2" in overall length. The end with the 90 degree bend attaches to the core support. Paragon's part number for the part is 2036K. Is this the rod you got?
I don't know what the second rod they sent you is though. There is only one front support rod used on 68-72's (other than the 2 shorter rods used in each headlight assembly). The 74-82 nose support rod is much shorter than the 68-72 rod, as it ran from the surround header reinforcement bar (the bar under the surround, between the headlight openings and the hood), down to the bottom of the core support.
Old Dec 6, 2010 | 01:44 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Mine bolts to the bottom of the radiator support and to the horse collar bumper support at the peak of the nose.
How much too long is your bar? If it's minimal, the nose is down and needs to be raised. If it's way too long, you may have the wrong bar.;
Old Dec 6, 2010 | 05:30 PM
dbeall1968's Avatar
dbeall1968
I bought one on E bay, it is also too long. I will wait to see what is said here. i have the AIM, showing the mounting, but the support is far too long. Did they run them all the way through '68 production? Mine is a June car, so maybe this was an early part that was discontinued. I was considering cutting the rod in the middle, threading the ends, and using a threaded coupler to adjust the length. Thanks for the thread!!
Old Dec 6, 2010 | 05:37 PM
John 65's Avatar
John 65
Early 68 here. No rod on my car, it bolts directly to the horshoe bracket.
Old Dec 6, 2010 | 05:57 PM
Alan 71's Avatar
Alan 71
Hi,
On my 71 the right angled end of the rod bolts to the bottom of the core support. The bolt comes through the support from the rear side of the support to the threaded hole in the rod. The spoon shaped end of the rod has a threaded hole and receives a bolt that has passed through a hole in the steel reinforcement that is flat riveted to the very front lip of the front clip. The rod passes above the large center bumper support in order for the bolt and hole to line up.
Might/must be different in earlier cars?!? What a surprise!
Regards
Alan
Old Dec 6, 2010 | 06:15 PM
John 65's Avatar
John 65
Heres a pic of mine. No bar.
Old Dec 6, 2010 | 06:30 PM
DZRick's Avatar
DZRick
I've got a June built '68 that I'll try to get some pictures from ( not in the best place for picture taking) I've also got a spare rod from another June built '68 that I can measure if anyone needs me to and I can find it..
Old Dec 6, 2010 | 06:49 PM
woodsdesign
My rod is 20 1/2" long. I found out that how it is installed. Now I am wondering if all the cars had them. Mine looks just like John65's photo.
What is that bracket on the right side of the front support? Does that have anything to do with the rod? I will be at the shop this weekend and see how it fits.
Old Dec 6, 2010 | 07:05 PM
John 65's Avatar
John 65
That bracket reaches over the top and bolts to the front support (the long one, from side to side that connects to the fiberglass)with 2 bolts.
Old Dec 6, 2010 | 07:56 PM
woodsdesign
John,
I know that; but what is it for?
Old Dec 6, 2010 | 08:18 PM
Manuel Azevedo's Avatar
Manuel Azevedo
My very late 68 bolts to the bottom rad. support and to the nose reinforcement just above the horse shoe bumper support and is about 20inchs long.
Old Dec 6, 2010 | 08:42 PM
John 65's Avatar
John 65
John,
Thats just it...there is no rod.
Old Dec 7, 2010 | 07:22 PM
woodsdesign
Thanks John,
So just so I am clear, this takes the place of the rod. right?
Old Dec 7, 2010 | 07:34 PM
John 65's Avatar
John 65
Yes, on my car at least, I have seen another one at a cruise night like mine also, but not often. Pulled my interior apart years ago, the word pilot is written on the back of some of the peices. Must be an early 68, sadly I dont know how early, but thats ok.
To 68 front support rods
