Few things I was given the GREEN light to add to this car, one being it will be a Hybrid with my hydrogen sysem I designed and billet aluminum pulleys. the biggest hundle I've been battling is finding billet aluminum pulleys for the water pump and the crank pulley. Everything I found work for the average small block but not for the Vette.
Those you have the billet aluminum pulleys care to share where you got them.
Summit Racing sales a set of March billet aluminum pulleys that fit the Corvette. Set MCH5070. They also carry individual pulleys for the water pump and crankshaft MCH5052 and MCH 5072.
I am seriously considering getting the same serpentine setup. Where did you get yours? Was it a kit and do you remember how much it cost? Thanks
Picked it up from summit, It's their compact kit for a big block vette. The March kit requires you to run a different ps pump and reservoir. All said and done it was just shy of $1k.
Corey, can you share details on how you mounted that power steering reservoir, which hoses you used, etc? I've been running my steeroids manual for years now (although I've only put like 500 miles on it maybe). I've had that pulley and bracket setup sitting in my garage for like 3 years waiting to be installed. I'm assuming you used the march pump as well?
