C3 question:
Old Dec 12, 2010 | 07:26 PM
C3DeedlyDee's Avatar
C3DeedlyDee
Default C3 question:
Hey guys I was wondering if anyone knew which model year of the C3 had the lightest curb weight. I checked how-it-works and they say that it's the '69 model, but I was wondering if anyone knew a site or knows personally if this is right or not.
Just wondering because I'd like to get a C3 and swap out the engine and transmission for an LS2/T56 combo. Does that yield any reduction in weight compared with the stock engines/transmissions in these cars?
Old Dec 12, 2010 | 07:54 PM
dbeall1968's Avatar
dbeall1968
1968 sb coupe-3260 pounds. That is a good start.
Old Dec 12, 2010 | 08:42 PM
U17's Avatar
U17
Look through here.. Might help ... http://www.motorera.com/corvette/1970/vet76.htm ... All gens ....
Old Dec 12, 2010 | 09:00 PM
C3DeedlyDee
Ah sweet thanks guys!
Old Dec 13, 2010 | 12:24 AM
thatcorvetteguy's Avatar
thatcorvetteguy
Your lucky the lightest is also the best looking---68
Old Dec 13, 2010 | 12:44 AM
terry82's Avatar
terry82
the ls2 motor is lighter than the stock 350.if you are looking for a c3 to hot rod or to make big changes to ,you will save a lot of money if you find a car that needs a lot of work .most c3s from 68-73 cost a lot even if they need alot .i would look at 74-82.in 82 they had thinner glass and had light weight rear spring .
Old Dec 13, 2010 | 10:42 AM
udornf4's Avatar
udornf4
My .02:
68-74. Specifically because they have true Dual Exhaust! I don't like fooling with catalytic converters (and simulated dual exhaust) ...
To C3 question:
