Door Panels
Thanks,
Paul
It may be possible to remove them, drill and tap a hole to accept a screw to reattach? I don't know if there's enough material there.
Did you check with Willcox? I heard something about some documentation being posted on this topic. Think it may have been Willcox but I'm not certain.
The lock plates are 'swedged' onto the door panel when assembled. You can just use a Dremel to grind off the (4) swedged heads to remove that plate. Then, to reassemble it, you can drill a small hole into each of those (4) posts and tap for small screws or use some JB Weld (knead-type) stick putty epoxy to form new heads to retain the plate, making sure you force some of the epoxy down into those drilled holes so it gets a good 'bite' on the posts.
To position other items...like the thin molding pieces, you need to carefully un-bend the 'spikes' on the backside so that they are straight and vertical before removing them. Then, when you remove them, you will not alter the position or size of the hole the 'spike' went through. Now, you can use a fine-tipped marker to place a mark in exactly the same spots in the mounting groove on the new panel so that the molding will fit in exactly the same way on the new panel. Sounds like excess work, but it is worth it for proper look on the new panels.
Even the "basic" panels will have the upper seal trip installed, so you don't need to worry about that. {That IS a real difficult disassembly/reassembly if you ever have to do it.}
Make certain that the new panel is not mis-shapen or warped before you install it to the car. If it is, you need to warm it up (sun or some heat lamps over the backside of the panel...not too close) so that it will bend a little and bolt up properly. Be careful on this, as the plastic body of the new panels can be brittle and snap if you bend on it too much.
Excellent advice, I could not have said it better, good job !!!
