Surging
Old Dec 17, 2010 | 12:02 AM
Clyfton's Avatar
Clyfton
Default Surging
Hello all,
1982 Corvette 62,000 miles
Was running fine but now won't run at all. When I start it, I get a backfire through the carburator, and wild surging until it stalls. It's like a bucking bronko to keep it running by attempting to compensate for the surging using the accellorator pedal. Then when it stalls there is a terrible stench of a fuel mixture way out of whack.
I've tried cleaning the IAC motors and replacing (adjusted to proper starting voltage) the TPS. I checked the injector fuses ... they were ok. When I removed the EGR to check it I found that it had been bypassed via a block gasket, so I removed it and installed a plate cover. Can't find a broken/disconnected vacuum line. Can't really check vacuum because engine won't run long enough. It is not throwing any Check Engine Codes. Wondering if I should spend the $150 on two new IACs.
Thanks in advance,
Cliff
Old Dec 17, 2010 | 12:08 AM
jdp6000's Avatar
jdp6000
I don't think the problem is an IAC. Its most likely your fuel pump. maybe just the fuel filter but not likely. Don't mess with anything else. Did you set the TPS back to .525 again? The IAC's may no longer be functioning. they need the car running for a few miles at 35 mph to reset if you diconnected and removed them. You have three issures to deal with now.
Change the fuel pump first.
If it was a sensor you would be getting a code.
Jim
Old Dec 17, 2010 | 12:09 AM
STINGRAY1WORD's Avatar
STINGRAY1WORD
Sounds like the fuel regulator is acting up.
Old Dec 17, 2010 | 12:11 AM
Clyfton's Avatar
Clyfton
Cool. Thanks. I realized right after I hit SUBMIT that I forgot to include that I adjusted the TPS to .525. so I edited my original post. I'll start looking for a fuel pump.
Old Dec 17, 2010 | 12:17 AM
Clyfton's Avatar
Clyfton
Stingray1word ... I'm looking at my shop manual ... are you talking about the Fuel Pressure Regulator on the rear unit? I see there is also a Fuel Pressure Compensator on the front unit. I'm new to the Corvette world so it may be a stupid question.
Old Dec 17, 2010 | 12:19 AM
jdp6000's Avatar
jdp6000
Don't chase everything. I went down the same road. Same problem. It was the fuel pump. Only other remote possibility is the hose in the tank from the pump to the lid. It deteriorates. If its the hose an over full tank of gas will minimize the surging.
Jim
Old Dec 17, 2010 | 12:21 AM
jdp6000's Avatar
jdp6000
Regulator is on the rear TBI. Its not really a regulator. It steps down the fuel pressure to 9-13 psi. But if the pump is gone it isn't getting enough fuel to step down. If the problem was in the tower you would be leaking gas. You may notice the rear TBI is spraying and the front is dribbling or irratic. thats a sign of a bad pump. speend the $100.
Jim
Old Dec 17, 2010 | 12:22 AM
STINGRAY1WORD
Hey no such thing as a stupid question as i was not aware of a fuel presure Compensator. But the system should be checked in this order.
1. fuel filter
2. fuel pump
3. fuel regulator
Old Dec 17, 2010 | 12:23 AM
jdp6000's Avatar
jdp6000
1. fuel filter
2. fuel pump
3. fuel regulator
Sounds about right. I still bet its the pump or the hose in the tank.
Jim
Old Dec 17, 2010 | 12:31 AM
Clyfton's Avatar
Clyfton
Thanks everyone ... now I have a plan.
Old Dec 17, 2010 | 12:40 AM
terry82's Avatar
terry82
i would look to see if the injectors are spraying fuel, if so are they spraying to much?if they are i would be looking at the coolant sensor at the front of the motor .that sensor talks to the computer not the gauge.http://www.crossfire.homeip.net/index.php?act=idx
Old Dec 17, 2010 | 12:53 AM
Rebelrob's Avatar
Rebelrob
Clyfton, I have a 82 fuel pump for sale if your interested. From the looks of it, it was replaced at one time, so I think its newer than the original 82. Never had a problem with it, just went to a mechanical and did not need it.
Old Dec 17, 2010 | 01:12 AM
Clyfton's Avatar
Clyfton
Terry82 ... when you say look at the sensor ... are you saying visually inspect it? replace it? or is there a way to test it? I tried clicking on the link in your post but that didn't seem to go anywhere related.
Old Dec 17, 2010 | 01:26 AM
terry82's Avatar
terry82
if you are duming in a lot of fuel then the sensor is bad .yes you can check it when its cold an then check it when its hot .check with a ohm meter.that post goes to the cross-fire forum where you can get lots of help.
Old Dec 18, 2010 | 09:12 PM
Clyfton's Avatar
Clyfton
jdp6000 ... thanks a bundle ... you were right on
I replaced the fuel filter and fuel pump and she's purring like a mountain lion.
From the looks of things, they had never been replaced. So was well overdue.
I'm new to this forum. I know some forums allow for positive feedback points. I checked the forum rules and didn't see anything.
Thanks again,
Cliff
Old Dec 18, 2010 | 10:44 PM
jdp6000's Avatar
jdp6000
Thanks again,
Cliff
Thanks for the kind words Cliff. I am glad you got her fixed. Happy motoring.
Jim
Old Dec 19, 2010 | 03:33 PM
Clyfton's Avatar
Clyfton
Looks like I'm not out of the woods yet.
I went to start it this morning and apparently, whatever controls the cold idle is busted.
I had to manually give it some gas and warm it up before it would run.
It used to maintain a fast idle until it got warmed up. I can't believe so much can break at one time. How do I fix that? Does crossfire have a choke?
Thanks in advance,
Cliff
To Surging
Old Dec 19, 2010 | 06:32 PM
terry82's Avatar
terry82
the computer controls the idle .take a look at the injector spray and tell us what it looks like.
Old Dec 19, 2010 | 07:14 PM
Clyfton's Avatar
Clyfton
Injector spray is conical with the cone the same size as the port. The spray clicks on and off rapidly with a slight dribble down the center. I made a 9MB Quicktime movie of it here http://cid-4054561e39209849.skydrive...1E39209849!159
You'll need Apple QuickTime available here http://www.apple.com/quicktime/download/ . If you have an iPhone or iTouch then you already have it.
Old Dec 20, 2010 | 03:40 PM
terry82's Avatar
terry82
okay now you have a good spray.does this problem only happen when cold then goes away after warm up?have you pulled a plug to see how its burning ?did you check the iac?you may have one that is not seating well .did you sign up for the cross-fire forum.there is a lot of info there on how and what to check a cross-fire.
