power windows
Old Dec 17, 2010 | 04:08 PM
1977L82's Avatar
1977L82
Default power windows
I'm having problems with my Windows my passenger one is slow and weak and my driver one isn't working I ordered new switches any ideas on the passenger window
Old Dec 18, 2010 | 01:25 AM
johnt365's Avatar
johnt365
If its never been done before, it probably couldnt hurt to disassemble and clean everything up then inspect and lube up before reassembly.
this process will also let you check for any binding parts that could cause the window to be slow.
On the driver side, I would remove the motor and test it.
Old Dec 18, 2010 | 02:51 AM
mopkop's Avatar
mopkop
Default windows
Relay is loose causing bad earth
Old Dec 19, 2010 | 06:12 AM
hunt4cleanair's Avatar
hunt4cleanair
John's got the right idea. You will be surprised what you find and over 30 years, how much gunk detracts from performance. I did my 78 door locks and also cleaned up the windows tracts. You may need to replace the power window actuators (motor).
Old Dec 19, 2010 | 07:30 AM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
Default Good Timing
I am having a similar issue with my 77 and I guess it is time to dig into the door panels this winter and pull those motors, then clean up the interiors.
I have been procrastinating this for a few months now but they are not working well so no better time than when the snow is on the ground I guess to get this done.
I do not wish to hijack your thread, but maybe to ask if anyone following the original request knows a good article on the repairs being proposed on the original thread could you share them with us here? Sure appreciate your help.
Good post and good timing for me, thank you for all the help.
David
Old Dec 19, 2010 | 12:04 PM
Peterbuilt's Avatar
Peterbuilt
Check the wires that are between the door and the frame.
David
http://www.corvettemagazine.com/content/view/87/
Old Dec 19, 2010 | 05:08 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
Excellent reference, thank you very much.
David
Old Dec 19, 2010 | 05:44 PM
Emeightch's Avatar
Emeightch
I had the same issues... Pulled mine apart, soaked/cleaned/scrubbed/greased/etc... and then realigned and now they work better!
To power windows
