So I got the kit that comes with 2 new Astro-Vent ***** and 4 new felt seals.
I put it all together (properly) and the ***** are way too tight in the new felts to turn.
I tried a little talc on the felts and still no help, my ***** are very sticky.
I presume that someone here has actually had to deal with this? What did you do?
I did save the old felts - but I'd feel really defeated if I had to put them back in.
Thanks in advance....
-W
I put the old felts back in with the new ball. They were tight enough to break something.
Seems my new ***** are slightly out of round.
They are good when closed and tight as hell when open.
-W
I don't think there was any way this thread couldn't have taken a wrong turn, given the heading. oh yeah, the commercial was hilarious BTW. Sorry Clams, I don't have any acutal advice for you, my 79 has no *****.
In the past, someone posted that repro vent ***** were slightly larger in diameter. When my felts lost their adhesive I used some open cell weatherstrip like on the center A/C outlets. It is more compressible and does not hold your ***** too tight. mike...
-W
I first took some fine grit sandpaper to the rough area on my *****, then i washed them real good , and finally lubed them up with a bit of vaseline . Popped them back in and they are as good as the day i was born.
