Power steering control valve leaking
Old Dec 22, 2010 | 08:07 PM
vish2000's Avatar
vish2000
Default Power steering control valve leaking
New to a C3 and valve leaking. rebuild?
Old Dec 22, 2010 | 08:42 PM
dgood's Avatar
dgood
Follow this link. It was provided by speedreed. I did it last month (twice). You have to follow all the directions to the T. I didn't and ended up doing it twice. I got the over haul kit at advance auto for 13 bucks. works like a charm.
Old Dec 22, 2010 | 08:43 PM
dgood's Avatar
dgood
http://www.cssbinc.com/images/ads/ho...structions.pdf
forgot to post the link. copy the link into your browser and it will work.
Old Dec 22, 2010 | 09:10 PM
68/70Vette's Avatar
68/70Vette
Excellent. I've got a used, and unused, PV somewhere. I'll try to find it and rebuild it. I bought a "new" PV for my 68 a very few years ago and it (or something) appears to be leaking.
Old Dec 22, 2010 | 10:44 PM
vish2000's Avatar
vish2000
Default steering valve
Thanks for your help and time dgood. Have a merry Christmas.
Old Dec 23, 2010 | 05:52 AM
dgood's Avatar
dgood
no problem. If you put it together wrong, when you start the car, the steering will jam all the way to the right and all you fluid will come out on the floor and all over the bottom of your car. Good luck
Old Dec 23, 2010 | 12:48 PM
gr8t73's Avatar
gr8t73
There is a procedure for centering the power steering control valve in the AIM. You should set up the valve following this procedure once it is installed.
Old Dec 23, 2010 | 10:43 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
....part of this procedure is to disconnect the rod end(castle nut & cotter pin)from the frame mount so it DOES NOT jam the steering one way or the other. It can't do this with the rod end disconnected, then you "center it" with that lock nut under that protective dust cap.
To Power steering control valve leaking
