Warning on HF engine hoist
Old Dec 23, 2010 | 04:59 PM
milo30's Avatar
milo30
Default Warning on HF engine hoist
Bought one of the folding engine hoists from harbor freight to do an engine swap. Was a good deal and only needed to use it once. Started pulling the motor and trans tonight and next thing I know the back corner was off the ground. I lowered the the engine and disconnected the chain and when I pulled the hoist out from under the car, one of the front wheels was off and the other had one bolt left on it. The bolts sheared off somehow. The hoist seems fine but the bolts are pretty cheap. Going to the store to get some stronger bolts to put the wheels back on.
Figured I'd warn others not to use those bolts that came with it. It could have been pretty bad if I hadn't noticed the side lifting and it had decided to go over while the engine was above the fenders or me.
Old Dec 23, 2010 | 05:04 PM
cm2dinger's Avatar
cm2dinger
That odd i've used my 2 ton from HF on several engine pulls and didnt have any problems. i'll have to dubble check my bolts though.
Old Dec 23, 2010 | 06:21 PM
milo30's Avatar
milo30
Just went out and put some new bolts in and everything works fine. Got the engine and trans out. Don't know exactly why it did that but no big deal with some good bolts. The ones that came with it were pretty frail.
Old Dec 23, 2010 | 07:55 PM
earthquake68's Avatar
earthquake68
I had a similar thing happen with a HF shop press. I forget what I was pressing apart, but half the bolts sheared all at once. Talk about puckering up. I put grade 8 bolts back then welded everything together so it's permanent. Those non-graded bolts they come with are no good when you test the load capacity of your tool.
Old Dec 23, 2010 | 10:43 PM
68/70Vette's Avatar
68/70Vette
I use a Harbor Freight engine hoist. I used it to pull my 68 engine and replace it with a ZZ4. I few years later I wanted to use it to pull my BB out of my 1970. In the ensueing years, the haudralic ram had lost it's seal. The chrome shaft out of the power ram had become corroded. I think that on quality units this corrosion would not have occurred. I bought new hydraulic ram. It cost about $70.00.
The startling point is that the equivalent Snap-On hoist costs about $1050. The Harbor Freight hoist which looks exactly like the Snap-On unit costs $179.00. Another eye-opening fact is that if you, or I, where in China, we couldn't ship the Harbor Freight engine hoist to us here in the US for anything like $179.00. It's pretty heavy. The Chinese government is really subsidizing the shipment of this stuff to the US.
The engine hoist is pretty good quality as far as the steel and welds go. The power ram is very cheap. But instead of lasting a long time, I could buy another one for just about $70.00.
Old Dec 23, 2010 | 10:52 PM
milo30's Avatar
milo30
Yeah, the actual hoist held up pretty well. It didn't give at all when the wheel went and it was tilted and I was tugging on it. Overall I think it's a decent made unit, just the bolts are the weak spot. Now that I have the engine and tranny out, I'm replacing all of them before I try to use it to install.
Wasn't a good day. Besides the wheel coming off, while folding the legs up to replace the bolts, I forgot to pin them in place and got sucker punched in the face by one of them. Then the tranny was hanging up on something and I was having a heck of a time getting it to come forward.....note to self: next time remove shifter before pulling trans.
But I got them out without damaging the car and just minor damage to my pride. I won't forget to pin the legs again though. They are heavy and I took it full force on the jaw!
Old Dec 24, 2010 | 02:15 AM
whitehause's Avatar
whitehause
I've had no problems with the hoist, but DO NOT USE the load leveler. I had mine break the first time I used it. Had the engine and trans at a pretty good angle, and the front metal strap that goes around the big worm bolt snapped. I still had it over the engine bay, so no real damage, but if it had been over a fender I'd be in small claims court.
Old Dec 24, 2010 | 09:43 AM
calif phil's Avatar
calif phil
I will not step foot in HF. The stuff is such poor quality I would rather borrow or rent if I could not afford to buy a decent tool.
Old Dec 24, 2010 | 10:40 AM
U17's Avatar
U17
I bought their engine stand when we pulled the 350 out... The bolts did not go in... Bought correct bolts, no problem.... But that's just the stand ...
Old Dec 24, 2010 | 12:08 PM
milo30's Avatar
milo30
I couldn't have gotten it out without it but it did look like it might not last. I was afraid of the same thing. Going to buy a better one to reinstall.
Old Dec 24, 2010 | 07:10 PM
rugerm44's Avatar
rugerm44
Folks even some of snapons junk is made in china.I bought an engine hoist from summit racing.Take a guess where its made.Five engine changes later its still working fine.I dont store outside so rust on the ram aint a problem.Also when you do store it retract the ram and oil down any exposed chrome.Just about everything requires a little care if you want it to last.The lathes the sell are pretty decent after you replace all the cheap bearings in them with quaility units.They have too much play in them.
Old Dec 25, 2010 | 10:47 AM
HobbyPoor's Avatar
HobbyPoor
so you buy a cheaper product to save money...and it breaks...and then you would sue those who sold it to you?...ok
Old Dec 25, 2010 | 11:03 AM
whitehause's Avatar
whitehause
When it says it's rated for 1500 lb's and it breaks with 700 on it, then yes.
To Warning on HF engine hoist
