I just was going to change out my power window switches when I unscrewed the parking brake console and it was really butcher when they TRIED and put it together. They glued the console on top of everything. It looks like I have all the right parts in there -
Do the repro consoles have the screws attached to the underside and thus you screw everything back together before you put it in the car - thus the back reenforcement everything out and then assemble put back and screw??
Assemble everything and then place in the center and bolt in the back.. yes?
Yup. The only tricky part is getting the slider over the PB handle. There's a pre-moulded embossed line for where you need to cut it to slip over the PB handle. Then you need to reach behind the wall where the rear screw goes through to start the bolt by hand. It took me a few attempts to get it back together.
Glenn
