I am restoring a 1968. I am in the process of a frame off. I plan on replacing all wearable and service parts. I will be following the AIM in detail. Complete front and rear suspension rebuild, complete drive train rebuild, frame will be tanked, blasted and powder coated. New mounts. New brakes w/SS lines. New fuel tank and lines. New interior carpet, seat covers and door panel, body is being brought down to fiberglass any repairs will be completed and new paint back to original etc. You get the gist of the restore. So my question is: Can the car be officially documented as 0 miles or must I retain the 81,581 on the odometer?
Hi tp,
I think many people would have the odometer reset to zero when they have the gauges restored.
For me though, I'd leave the original odometer reading as documentation of at what point the restoration was done.
I hope you're selective in choosing what parts you replace and what original parts you restore. Remember VERY few reproduction and service replacement parts will exactly like the part you're replacing and MANY won't be even close.
Regards,
Alan
Interesting take on a restoration.... in my opinion the car traveled the 81K and even though it appears to have just rolled off the showroom floor, it has been over the road. I can't imagine the DMV in your state would be receptive to resetting the title for you either.
Good luck with the project and post lotsa pics. Would love to see it.
That was my thought also. Probably would be no problem setting your odometer back to zero - until you try to resell the vehicle. I would think it would raise a red flag at the DMV at the time of sale. I would think that they would require you to add the previous mileage to the new odometer reading for an accurate vehicle mileage.
That sort of brings up a related topic. For those doing extensive restorations of vehicles, do you ever have to get "Reconstructed Titles" when vehicles are resold? I know in our state, vehicles that are wrecked and the repair cost is 70% of the retail value, the vehicles are required to be retitled as "Reconstructed" - if they are repaired. That usually has a significant affect on value. Just curious.
I dont know about other states but in N.Y. if a vehicle is older then 10 years old the mileage is not an issue that would have to be dealt with on a transfer. If there is any $$$$ left over after you are finished why not just buy a new speedo and use that , keeping the original one as proof of the mileage when you "restored" the car ? Good Luck, sounds like you'll be busy, Peace,,, moosie
Don't throw anything away on disassembly until you have a replacement part in hand. There are quite a few "1968 only" parts on your vehicle and they can be time consuming and expensive to track down and replace. If you have the original, you can refurbish the part which is not currently available and use the vehicle while you track down those last elusive bits.
I'd leave the odometer reading where it is, as show's a bit about the car's character. Most state licensed speedometer shop's repairing odo's must be set to zero. Who the heck's kidding on a 40 year old car anyway.
I don't think it's possible to truly turn back the clock to when the car was new. Too many parts which are serviceable would need to be replaced. You can get close but probably never quite the same, hence the high value true originals will bring in. As Alan71 cautions, many reproduction parts are not exact duplicates, some quite disappointing.
If you reset to '0', I'd imagine many would interpret that to be 100,000 miles?
I'd say take many photos, document as much as possible while disassembling and restoring.
Excellent feed back. Thank you. I will keep the odometer as is. I will also be restoring the original parts the best I can. So far the only things missing, which are available are the original steering wheel and two AG 15x7 rims. Most everything else is in place and can be restored. I will be going through the suspension, drive train and interior soft parts. I do have over 200 pictures from the first time I looked at the car to the point it is at today. The car is being prepped for the body removal at 2ndGenerationRestoration in Walpole, MA. Stan (owner) is allowing me to strip the car and he will be showing me some fiberglass techniques. The body only needs minor attention before paint. Stan's shop will be doing the final body prep and paint. I will take the chassis home for the full restoration. I will post pictures as it starts to come along. I wish you all a happy and safe New Year.
Good idea.
Many street rods are put together with new instruments and the speedo odemeter is set to 0. I've done two so far with no problems.
I would agree with most replies regarding the odometer. However anything can happen when undergoing a complete restoration so i would just add that taking a few good pictures of the odometer with a date to reference it to will go a long way toward proving you have not intention to deceive a prospective buyer, should the mileage get reset or you need to replace the original speedometer.
