Another Paint Question
In my searches on this topic, I have found estimates anywhere from $4k to $15k. I am not looking for a show car, but just a paint job that is fitting for a weekend driver.
Ditto on the prep work; if you do it, you don't have to pay them to do it.
Gary
Often when the car is painted the new paint makes the rest of the exterior look a bit shabby. The paint job might lead to some new chrome plating and new trim. Perhaps you need to consider that too when you're thinking of costs.
I've never seen a Corvette that didn't need at least some body work once the paint is off.
Regards,
Alan
Regards,
Alan
Thats when you learn how to lay glass!
Not trying to hijack the thread, just curious what breathing equipment you used Mike. I want to try doing my 68 myself. I see a fresh air supply for 400.00 and was considering it. I bought the primer to seal the car, read the back of the can and got cold feet. Thank you.
Like lots of guys have said, knock down the cost by doing as much prep as possible at home. I am at the point right now on my 68 where it needs a good sanding and then ready to prime. Suprisingly enough, I had to "make" some wheelwell edges and for a 1st timer they came out pretty good if I say so myself. Once I gained a little confidence, it kept driving me to continue. Fixed several cracks at bonding stripps, improved door gaps, and just a whole lot of little cracks here and there in the body. So far the most work was removing all the paint. I know the body is a lot better than before I started. Not trying to make the worlds most perfect 68, just a clean, presentable, fun driver works for me ! Good luck.
As for Macco? This Impala was painted at Macco for $350.00 of course I did all the prep.
Give this a read and put some cash in your pocket!
If you want a good looking paint job you must have a perfect surface for it to be applied to, so yes, get all of the old paint off and build the surface back up with a good sandable primer. The cracks should be repaired when there is no paint or primer on the car.
The Impala looks good because I spent about 30-40 hours on the bodywork and preparation before it entered the paint booth.
90% of a good paint job is the prep work, so as stated earlier if you can do most of that yourself then you can save a lot of money.
It might seem a little overwhelming when you start, so just do one area at a time and learn tricks and techniques as you go, so pick someplace that doesn't need repair like a door and just concentrate on that until your satisfied and move to the next area and so on.
Your local paint supply store is a good place to learn also, I ask as many questions there as I can when I'm buying my supplies and of course here on the forum there is a lot of knowledge to share.
Good luck, and be sure to post pics along the way.
