Touching up Center Console??
Old Jan 2, 2011 | 11:15 PM
ultimix's Avatar
ultimix
Default Touching up Center Console??
Anyone ever just touch up there center gauge console - I was thinking about taking it out and spraying it.. but there are just a couple of places that need to painted..
Has anyone just got some black paint and did a little touch up to it?? Is so.. what did you use..
Am I crazy thinking this...
Mark
Old Jan 3, 2011 | 03:11 AM
stinger12's Avatar
stinger12
I just stripped and repainted my console plate using spray paint from home depot...
Next is the gauge console bezel.
Have at it.
Old Jan 3, 2011 | 06:27 AM
MarkBullis's Avatar
MarkBullis
Have at it.
How did you get the silver strip back on it?
Old Jan 3, 2011 | 06:35 AM
corvetteload's Avatar
corvetteload
The "silver strip" is chrome plating, use masking tape and tape it off and trim with an x-acto knife. I usually sandblast then and repaint. Pull the tape off and PERFECTO!!!! If any errant paint just take the tip of the x-acto blade and scrape from the chrome (and no, won't hurt the chrome, unless you press real hard, just use blade at angle and scrape).
OR, if your touch up isn't bad, use a black Sharpee
Old Jan 3, 2011 | 06:45 AM
ultimix's Avatar
ultimix
I was thinking about a sharpie..
Old Jan 3, 2011 | 10:48 AM
75+78 Corvettes's Avatar
75+78 Corvettes
if it's just a few little nicks that would be fine but any more than that the dots will stand out like a sore thumb. Trust me on that. I gave up and just repainted all of mine. I used Semi-gloss trim paint
Old Jan 3, 2011 | 02:26 PM
GD70's Avatar
GD70
I used a small fine point hobby paint brush and Krylon satin black paint.
I was touching up small chips and when I was done, it's virtually unnoticeable.
Glenn
Old Jan 3, 2011 | 02:31 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...what did you use...
Krylon 5-ball semi-flat black from the rattle can.
Old Jan 3, 2011 | 02:34 PM
Tom73's Avatar
Tom73
I used Krylon semiflat black spraycan, sprayed the entire thing. Once good and dry I took a soft cloth and used laquer thinner to clean off the chrome accents. Worked great.
Old Jan 3, 2011 | 03:10 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by Tom73
...sprayed the entire thing. Once good and dry I took a soft cloth and used laquer thinner to clean off the chrome accents. Worked great...
Yep. I did the same.
For the touchy areas, you can use lacquer thinner on a q-tip.
Old Jan 3, 2011 | 03:38 PM
DustersVette's Avatar
DustersVette
I did the same, do yourself a favor and do the entire area! You'll notice the difference.
Old Jan 3, 2011 | 05:39 PM
Alan 71's Avatar
Alan 71
Hi,
I still vote for painting the whole bezel and then as soon as the paint 'flashes' use a new x-acto blade to slice the paint off the top surface of the chrome trim. It comes off in long 'strings'.
When I tried tape I always ended up with too thick an edge on the paint.
Regards,
Alan
Old Jan 3, 2011 | 05:46 PM
MarkBullis's Avatar
MarkBullis
My 77 is not chrome plated... it looks more like silver paint because it's rubbed off everywhere
Old Jan 3, 2011 | 09:20 PM
ultimix's Avatar
ultimix
as always..
thanks guys!
Mark
Old Jan 3, 2011 | 10:31 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
Go to a hobby store/craft store. Get a bright silver paint pen. Then just go over the dull chrome.
To Touching up Center Console??
