Spare Tire Lock Boot
Old Jan 6, 2011 | 10:48 AM
Raptor119's Avatar
Raptor119
Default Spare Tire Lock Boot
Any good ideas out there on how I can install a new spare tire lock boot onto the lock assembly? Seems like something will have to get s-t-r-e-t-c-h-e-d a long way to get ovre the lock assembly and I don't want to tear the rubber boot.
Anyone done it before? Boot and lock are for a 1968.
Old Jan 6, 2011 | 10:59 AM
garage-ghost's Avatar
garage-ghost
I've done it but it has been a long time. I think I just ran it under some hot water gave it a shot of silicone and went at it.
Old Jan 6, 2011 | 04:29 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
if i remember correctly when i did mine, i used a hair blower to provide a bit of heat to it to make it a bit more pliable and then just stretched it over the lock. seems i remember it being harder than i thought it would be.
Old Jan 6, 2011 | 04:30 PM
Alan 71's Avatar
Alan 71
Hi,
I agree that warming the boot first allows you to slip it on without tearing it.
Regards,
Alan
Old Jan 6, 2011 | 04:47 PM
Patrick73's Avatar
Patrick73
"if i remember correctly when i did mine, i used a hair blower to provide a bit of heat to it to make it a bit more pliable and then just stretched it over the lock. seems i remember it being harder than i thought it would be."
I have a heat gun which works great, but hair dryer can also work. I would think that the hot water method would also make the boot much more softer and pliable.
Used these same methods on the plastic/rubber seat belt covers to slip them over the metal end piece.
Old Jan 6, 2011 | 10:36 PM
Raptor119's Avatar
Raptor119
I will try the hair dryer and let you guys know. Thanks for the input!
Old Jan 6, 2011 | 11:44 PM
68AIR's Avatar
68AIR
If I recall I softened it Also I turned it partly inside out which made it a lot easier.
To Spare Tire Lock Boot
