help
Old Jan 7, 2011 | 01:02 PM
briz's Avatar
briz
Default help
hello everybody.
i'm writing from Italy,my name's briz
I 've C3 1968 conv. white.
I would know if some of you can help me to find a wiring harness for the start ignition.
my vette, doesn't climb original ignition switch key near the tachometer, but it's mount at base of Column, and now I'd change the position of the switch, but the connectors are different ( from '68 to up),so i must to cut the wires on to the old switch, mount at the base of Column,and to attach the news but I don't know how, because I don't know the right position of the wiring harness.
help me guys....
thank 's in advance.
briz
Old Jan 7, 2011 | 01:50 PM
garage-ghost's Avatar
garage-ghost
Free wiring diagram here:
http://forums.corvetteforum.com/c3-g...or-anyone.html
Old Jan 7, 2011 | 02:58 PM
briz's Avatar
briz
thank you garage-ghost,
I read it before write my thread, but it's old and now no answer are available, i suppose that papawana send out all the wiring diagrams.
I ask for some one's advice
Old Jan 7, 2011 | 05:46 PM
Scott Marzahl's Avatar
Scott Marzahl
Ciao Briz,
This is wire diagram is cosi cosi but maybe some help. Does your new switch have anything written on the terminals?
http://willcoxcorvette.com/instructi...e%2068%202.JPG
This PDF is fantastico: http://www.nrjvette.com/johdotukset/...tte%201968.pdf
Batt = Red 12 gauge
Acc =Brown 12
Sol =Purple 12
Ign =Pink 12
Key- =Black 20
Key+ =Pink/black 20
Grd = unused,blank
If you need more help try a PM to Roger in the C3 technical section.
Ciao,
Scott
Old Jan 7, 2011 | 07:11 PM
briz's Avatar
briz
Thank u (grazie )Scott for your help.
the pdf is great.....
1 question:
what mean, the numbers side the colors??12 and 20?
Old Jan 7, 2011 | 07:25 PM
Red70vette's Avatar
Red70vette
Those numbers refer to the guage of the wires. The lower the number the larger the wire.
Old Jan 8, 2011 | 12:21 PM
Scott Marzahl
Prego, Briz let us know how the new switch turns out.
Old Jan 8, 2011 | 04:15 PM
briz's Avatar
briz
of course guy....
thank u everybody for ur help...
next time I'll post some pics about my vette.....
bye bye
Old Jan 9, 2011 | 12:45 PM
briz's Avatar
briz
Hi guy...
today I tested the new sequence of the wires for the new switch ignition.
all ok..
very good, the vette start, but now I 've a new problem:
how can I remove the block for the steering wheel and gear lever in automatic transmission?because before remove the old start ignition switch, the key provided also to release the gear level and steering wheel when I turn on the key, but now, inside the steering column ther is something that stop the gear level ans steering wheel agan.
i don't want use my vette with 2 keys....one for the start ignition and one for unlock the gear level and for the steering wheel...
thank's
briz
Old Jan 9, 2011 | 01:57 PM
PRNDL's Avatar
PRNDL
It sounds like you have a 69 style steering wheel with the ignition key and column lock on the steering wheel. But you have moved the ignition key/switch to the correct 68 spot on the dash, is that right? So now you have 2 places for the ignition key, one on the dash to start the 68, but you still have the key hole on the column and you need to use that to unlock the steering column and get the automatic trans out of park? Oy veh!!
Ultimately it would be nice if you replaced the steering column with a 68 steering column without the extra hardware. Short term maybe somebody will have a suggestion.
Old Jan 9, 2011 | 03:19 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
Originally Posted by briz
hello everybody.
help me guys....
briz
curious from italy what the VIN # of this car is ?
Old Jan 9, 2011 | 05:14 PM
briz's Avatar
briz
yes PRNDL..
that right
it's difficult for me to find steering wheel for '68 model in Italy, and buy it new it's expensive, because i've to pay the shipping and duty, and is not good idea......
it's not a problem for me have 2 places for ignigtion key, one hole i'll close, but it's how unlock the steering wheel and gear level....
please give me advice.....
P.S
427 six pack
next time, maybe tomorrow, i'll give u VIN my vette, now it's too late...(23:08) and i don't remember...
Old Jan 10, 2011 | 01:08 AM
briz's Avatar
briz
for all owner of '68 model, 2 questions:
first one:
do u have steering whell lock inside steering column, or is always free the steering wheel, also after remove the key from the swtich ign.?is it possible to lock ur stering wheel?
last one:
the same question about ur gear level for A/T.
is free the gear level or lock in P when the engine is turn off?
to be patient guy, and thank's in advance for ur help
Old Jan 10, 2011 | 10:21 AM
PRNDL's Avatar
PRNDL
68 steering column does not lock. That was an anti-theft device introduced in the 69 model year, and they moved the ignition switch from the dash to the steering column. I am not sure what lockouts are on a 68 automatic transmission, but I don't think the ignition switch has any effect.
To help
