under dash repair
Old Jan 15, 2011 | 05:41 PM
biscuitville's Avatar
biscuitville
Default under dash repair
The plastic under the dash that one screws the upper portion of the windshield wiper control bezel into is worn out - badly cross threaded. I don't believe I can simply put in a larger screw without breaking it. Does anyone know of a product that would allow me to plug the hole and then drill into it? I was considering JB Weld but thought that it would be harder than than plastic and possibly make drilling more difficult.
Old Jan 15, 2011 | 05:59 PM
RU7376vettes's Avatar
RU7376vettes
I have had a lot of success with Locktite's Plastix Bonder. Dries in about 20 minutes.
Old Jan 15, 2011 | 06:23 PM
Alan 71's Avatar
Alan 71
Hi bv,
Another suggestion.
I've had some luck using very small plastic dry-wall anchors from the hardware store. They're often used to hold the fastener for hanging a picture. They come in various sizes. Find one that's a snug fit in the stripped hole and then the screw enlarges it just enough to hold it in place.
Regards,
Alan
Old Jan 15, 2011 | 06:46 PM
69ragvette's Avatar
69ragvette
Default epoxy
the best thing I have ever used to repair plastic is 3m 8115 it is expensive but it works plastic,metal aluminum even after I weld I use it to seal
Old Jan 15, 2011 | 09:07 PM
biscuitville
Thanks everybody!
Old Jan 16, 2011 | 10:36 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Alan 71
...I've had some luck using very small plastic dry-wall anchors from the hardware store...
That's what I used.
To under dash repair
